It is currently Mon Nov 30, 2026 8:19 am
PostPosted: Mon Feb 06, 2012 4:34 am
Car Model: 1962 Valiant R Series - Australian (1961 in USA.)
G'day guys,
just thought I'd share a picture of what happened to me today.
I was taking a transmission line off my old 1962 Valiants, unscrewing the pipe fitting from the box. It was pretty tight, and was very hard to move. After a while I figured out why I wasn't getting far, and why it was hard......(see picture).
Peter
In the end, I had to use the Dremel to get it off.....all fixed now. :twisted:
1962 Chrysler Valiant "R" Series (Australian) - 61 V200 in U.S
Life Member - R&S Series Valiant car Club N.S.W
http://www.1962valiantclub.com
PostPosted: Mon Feb 06, 2012 5:01 am
Steps to taking off line successfully:
- Spray with PB Blaster
- Do other projects for a couple of days.
- Remove line.
:D
Glad you got it fixed, though. We've all been there.
- Mac
PostPosted: Mon Feb 06, 2012 11:02 am
The pipe to flare adapter fitting is supposed to stay in the transmission case when the cooler line is removed. Use a backup wrench to make sure the adapter fitting stays in the case while the steel tube nut is loosened.
PostPosted: Tue Feb 07, 2012 2:59 am
G'day guys,
you should have seen how i got the rear one out - straight into it with the Dremel. Then made up new lines and cleaned up all the fittings.
Job Done. :D
PostPosted: Tue Feb 07, 2012 4:25 am
Thanks heaps, Peter. Now I want a cinnamon bun, but I haven't any and it's 4-something in the morning so I can't go out and get any, and even if I could I'm sick with the flu, and even if I weren't they're not very beard-compatible.
So thanks heaps. Image
PostPosted: Tue Feb 07, 2012 6:34 am
Hey Peter getting your car ready for the national rally? Hope to meet you in Perth!!!
PostPosted: Tue Feb 07, 2012 7:05 am
Your PIC just reminded me: I've got a WAY overdue package that was supposed to be coming in the mail last week...
obliquely-inclined state of mind
PostPosted: Tue Feb 07, 2012 8:53 am
Is any food beard friendly Dan? :mrgreen:
Been there, done that Peter. :lol:
PostPosted: Tue Feb 07, 2012 9:41 am
Don't be a "glass-half-empty" kinda guy, Dan: do as I do and think of your beard as a convenient place to store bite-sized morsels of food for later...
PostPosted: Tue Feb 07, 2012 9:55 am
Like I tell my niece, I use my beard to save food for later. :wink:
PostPosted: Wed Feb 08, 2012 9:55 am
Being from the rust belt, I usually found that the flare nut stuck to the tube despite trying various penetrant oils. I now prevent that by putting just a little anti-seize grease on the back side of the flare and on the threads - since I've done that, I've never had the problem.
I also tried the trick of using a flaring tool to hold the tube while turning the nut, it sometimes worked.
PostPosted: Wed Feb 08, 2012 10:16 am
Blue tipped smoke wrench and PB Blaster.
PostPosted: Wed Feb 08, 2012 11:33 am
Teflon tape FTW. The thick yellow gas-line variety.
