It is currently Thu Oct 01, 2026 9:03 am
 Post subject: 7 1/4 weight
PostPosted: Thu Sep 08, 2011 3:23 pm
Anyone know how much a 7 1/4 rear weighs? Just the rear no brakes/backing plates. Think its under 100 lbs?
PostPosted: Thu Sep 08, 2011 5:14 pm
Depends on BBP or SBP and a few other things (diff type), but I'd say 105 lbs would be close with no brakes or backing plates at all.
PostPosted: Thu Sep 08, 2011 5:15 pm
Its a SBP open 3.23. Greyhound has a 100 lb weight limit,im hoping it is at that or a little lighter.
PostPosted: Thu Sep 08, 2011 5:29 pm
I just put my old one on the bathroom scale, ( I took it from the bathroom...), and it read 111.5lbs. It is compleat minus all of the brake hardware except backing plates, slave cyls and brake lines plus a bit of road grime.
SBP 2.76 out of my '68 Dart
Mike
An officialis Tyrde-Browne Racing membrum
PostPosted: Thu Sep 08, 2011 5:38 pm
I think Dart270 is just about right. Might be able to drop a few more lbs if it was drained of all the gear lube, but it will be right at 100+lbs without any "packaging"
Mike
PostPosted: Thu Sep 08, 2011 5:41 pm
Mike and Lou, thank you both for all of the info. Thank you Mike for the manual labor :D Any of you guys ever shipped a rear end before? I wonder how strict Greyhound is on that 100lb limit .... :twisted:
PostPosted: Thu Sep 08, 2011 5:49 pm
Well, it was not "that much" labor, it is still in the drive way, right where I left it. :lol: If they are that precise on the weight, maybe pull one or both axles and ship separate..??
PostPosted: Thu Sep 08, 2011 6:07 pm
:lol:
Could do that,its all up to the seller and how much work he wants to do for me on a cheap part like that. Shipping is going to cost$$$ I am trying to get a "cheap" upgrade,its already starting to add up :?
 Post subject: 7.25 compared to 8.25
PostPosted: Mon Feb 06, 2012 11:53 am
Car Model: 1962 Dodge Lancer GT Black/Red
Anyone know how much more the 8.25 weighs over the 7.25? Is the difference enough to affect fuel economy, performance our handling in an early A-body?
PostPosted: Mon Feb 06, 2012 12:26 pm
:lol:
Pull the axle shafts, backing plates and drain the oil, then they are around 80 lbs.
Have the user reuse his current axles and brake assemblies... or ship them in a seperate package.
PostPosted: Mon Feb 06, 2012 12:39 pm
This is in reply to Rapom's post from Sept. 2011.
Did you ship the 7.25? Do you still need one? in Texas. :shock: Reply here.-Dan
1964 Dart GT
