It is currently Mon Oct 26, 2026 9:00 am
PostPosted: Thu Feb 16, 2012 12:47 am
Hi again
Im just wondering, on a standard factory slant six equipped with Holley 1920, what keeps the throttle lever (and butterfly) in the closed position? I would imagine some kind of spring? If so, where should this spring be connected to?
Here is my current setup (see the spring on the right)
I do not have the well type choke thermostat there at the moment but soon i will, so where should I connect the spring to then (i mean as per factory)?
Thanks.
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Thu Feb 16, 2012 8:18 am
Syed,
Click on the red link below my name to view pictures of the spring attach points.
PostPosted: Thu Feb 16, 2012 10:56 am
You're missing the throttle spring bracket.
PostPosted: Thu Feb 16, 2012 12:13 pm
What Dan said:
I happen to have an extra one barrel throttle return spring bracket gathering dust in my garage. Are you interested in it?
PostPosted: Thu Feb 16, 2012 1:05 pm
Put me 2nd in line if Syed doesn't want it :wink:
PostPosted: Thu Feb 16, 2012 1:19 pm
I think I might have two, as well as some old Holley and Carter one barrel thermostatically assisted choke pulloff coil assemblies. I need to go dig around in my parts stash.
PostPosted: Thu Feb 16, 2012 1:37 pm
I believe I have one also, in case reed cant find his second one
Seth
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Thu Feb 16, 2012 3:13 pm
Note the pictured throttle spring bracket is a later variety, not the more vertical type that would have come on Syed's '66. The later horizontal spring bracket requires a spring with an extended hook/leg as shown in Reed's photo, not the type shown in Syed's photo.
PostPosted: Thu Feb 16, 2012 3:17 pm
Ah! Thanks for pointing that out Dan. I'll see if I have the other style bracket.
PostPosted: Thu Feb 16, 2012 3:50 pm
…or a spare long-legged throttle spring...
PostPosted: Thu Feb 16, 2012 4:04 pm
I probably DO have an extra long-legged spring.
I found these while I was rooting around in one of my parts bins in my attic:
The throttle spring bracket on the far left is the one i posted a picture of before. The second throttle return spring bracket looks like it is another late version that has had the leg cut off and the spring loop arm bent a bit. The thermostatically assisted choke pulloff assembly looks like it is for an early carb with the closed well, but I don't know if it is a Holley or a Carter. Unfortunately, it looks as if the rod for the choke linkage has ben bent out o its original shape.
I might have more parts squirreled away, but I need time to dig them out.
The simplest solution is for you to bend up a piece of metal, bolt it to the motor, and run a spring from the carb to the piece of metal.
PostPosted: Thu Feb 16, 2012 4:25 pm
Is this the vertical one you are talking about Dan?
Image (pic taken from FABO)
If so, anyone has this? or maybe a well-type choke thermostat for pre-'73 as well? anyone?
Anyway, I managed to make a quick make-shift bracket for temporary use, until I can get the correct one. Obviously this would not work with the choke thermostat in place...
Syed
PostPosted: Thu Feb 16, 2012 8:11 pm
Yes.
PostPosted: Thu Feb 16, 2012 8:45 pm
Yes.
If anyone here has one on their motor, and dont mind taking it off (or can measure in situ) and give me a rough measurement... I would be greatly appreciated. Looks simple enough that I can locally fabricate here.
Thanks
Syed
PostPosted: Wed Feb 22, 2012 7:42 pm
Hi Reed, did you find anything?
Syed
