It is currently Wed May 27, 2026 10:28 pm
PostPosted: Mon Feb 20, 2012 6:04 pm
installed a rebuilt alt and a new reg on my home biult rat rod cant get it to charge. 75 alt with 2 fields. wired to instructions, but i have a volt meter instead of amp meter. when i hook the wire from the balast resistor to the center pin on reg it pops the ign fuse. sure could use some help thanks
PostPosted: Mon Feb 20, 2012 7:57 pm
What schematic did you use?
something like this?
or something from here?
PostPosted: Mon Feb 20, 2012 8:03 pm
6 Pack Dart
Volt meter should connect between voltage plus and ground.
Richard
PostPosted: Tue Feb 21, 2012 12:03 pm
Go back and double-check your wiring setup to make sure it looks like this, and make sure you didn't accidentally create an open circuit in the charging line when you took away the ammeter.
PostPosted: Tue Feb 21, 2012 5:45 pm
Ummm Dan that schematic has too many cylinders... :wink:
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Tue Feb 21, 2012 7:00 pm
thanks Dan got it chargin like a ragin bull
 Post subject: mopar rat rod
PostPosted: Tue Feb 21, 2012 7:03 pm
hey guys , how do i get a pic on my post like you cool guys have lol. thanks for the help AL[/img]
PostPosted: Wed Feb 22, 2012 6:25 am
Host the pic somewhere, like photobucket. Make sure it's small enough to meet guidelines, or Guido will get you. Look in how to use this forum about that.
Put the link to the pic in your signature.
That easy!
 Post subject: Re: mopar rat rod
PostPosted: Wed Feb 22, 2012 8:41 am
Are you talking as a signature or under your name over there
MRO....
 Post subject: pics
PostPosted: Wed Feb 22, 2012 6:18 pm
both would be nice if you have the time to thanks
