It is currently Wed Oct 14, 2026 1:22 pm
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 1 … 22 23 24 25 26 … 128 Next
PostPosted: Mon Mar 05, 2012 9:09 am
Is that some kit, Rick? Looks great.
 Post subject: Seat belt
PostPosted: Mon Mar 05, 2012 12:09 pm
Just the Wesco 3 point seat belt and their $10 mounting kit. That has the floor L bracket and large washers, bolts and the insert that goes up inside the post for the top mount. About $85 with shipping.
Rick
PostPosted: Mon Mar 05, 2012 12:21 pm
Cool, will look into that.
PostPosted: Mon Mar 05, 2012 3:46 pm
Nice looking belt kit Rick. :D
 Post subject: Seat belt install
PostPosted: Mon Mar 05, 2012 5:28 pm
The kit said to drill a second hole below the hole you have to drill for the mounting bolt to go through. It would have been about an 1 1/4 if I remember correctly. This is where they said to install the reinforcement plate through. It would be covered by the seat belt assembly but I did not like the idea of another hole there. Plus I though it would weaken that area substantially. So I drilled the hole for the anchor bolt and then drilled the 2, 1/8" in holes where the rivets go. I then took a wire and fished it down through the top 1/8" hole and out the bottom. I ran the wire through the reinforcement plate and pulled it back up to the hole for the mounting bolt. Screw in the bolt, and that holds it in the post, and then take the wire off and put in the 2 rivets. Voila you now have a nice 3 point seat belt.
I did have my window mechanism's removed but I still think you have room to get that plate up through the post.
Rick
PostPosted: Tue Mar 06, 2012 12:56 pm
Nice!
 Post subject: Re: Seat belt install
PostPosted: Tue Mar 06, 2012 9:57 pm
Those backing plates do fit up into the B post without to much trouble when the windows are installed. I installed a Juliano kit which is similar to this one. I also bolted them in instead using rivets.
 Post subject: More stuff
PostPosted: Sat Mar 10, 2012 9:04 am
I got all my new carb stuff hooked up, and made new some new brackets. I reinstalled the wire loom that it seems I have removed 25 times. I also took care of the ground back at the rear tail lights and now they are working.
I also installed something top secret. Savvy racers will recognize it. Only 2 of them exist. And I think Rob has the other one.
Waiting for Lou to send me a front E-brake cable, and hopefully get that all fabbed up. I am running both cables up the left side with a straight shot at the front cable. Picked up a new long truck cable on E Bay to allow me to do this for about $9. All the bracket for the rear cables were cut off when I put in the inboard spring kit anyhow, so I am just putting them where I want them. Pictures to folow of the E-Brake
Had to add a little "Chrome"
Top secret Weapon, I may go right to 11's on the 1st run.
:lol: :lol:
PostPosted: Sat Mar 10, 2012 4:55 pm
That is very cool! :D
I don't have the other one though. Maybe Possum does... :lol:
PostPosted: Sat Mar 10, 2012 8:16 pm
Slowed my car two 10ths.Guzzi mark
PostPosted: Sat Mar 10, 2012 8:21 pm
SORRY,screwing with ya.I dont even have a clue of what that is.Guzzi Mark
 Post subject: Shake down run
PostPosted: Tue Mar 13, 2012 4:54 pm
I looked at the Calendar and it looks like I may try and do a Test & Tune on
April 7th at Mason Dixon. probably 2 or 3 Covalts and we'd love to have anyone else local that can come out. I'll post over in the event calendar also.
The Bamboozler was a Ron parker invention to get at Slantzilla if I remember correctly. The proper term was a "bagel bamboozler" I think, and it may have been a special term for a turbo. All in good fun.
Rick
PostPosted: Tue Mar 13, 2012 5:24 pm
That's what it was Rick. I am still bamboozled too, I nor anyone else have ever seen it. :shock:
 Post subject: Update
PostPosted: Thu Mar 15, 2012 5:13 pm
No time for pictures, but I got my front half of my leaf springs clamped, installed a new overflow bottle, and got the Emergency brake cables run to where I want them. I need to make a small bracket for the E-brake front cable and hook it up and it should be good to go. Also got some header collectors and bolted them on so the flanges aren't vibrating!
We are headed out to Mason Dixon on Saturday morning for some initial runs. I don't have the spool in yet and I only have narrow street tires but we will see how it does. I'm sure traction will be a problem. Car should run 15's I would hope. We shall see.
At the present time I am just happy to have it running. Mason Dixon 2009 is when I started working on this car again. 3 years went pretty fast and I want to thank everyone on this site for their encouragement to get it done. It has been a lot of work and a lot of fun. Hopefully from here on out isn't quite as labor intensive, and is a lot more fun.
Thanks again!! See ya Saturday!!! :lol: :lol: :lol:
Rick
PostPosted: Thu Mar 15, 2012 5:17 pm
Cant wait to see the BAGEL BAMBOOZZLER IN ACTION - ADDS 250 HP!
:D
See you sat!
