It is currently Wed Feb 26, 2025 5:12 am
 Post subject: Axle Seal Removal
PostPosted: Thu Mar 08, 2012 1:44 pm
Hey guys, I seem to have misplaced my service manual...
What's the proper way to remove the axle seals on an 8 3/4" housing? Do I need a special tool?
vm
PostPosted: Thu Mar 08, 2012 2:29 pm
I just use a pair of channel locks, or big screw driver, and pop it out.
PostPosted: Thu Mar 08, 2012 2:40 pm
Thanks. I'll give the channel locks a try, but it hasn't even budged yet...
vm
PostPosted: Thu Mar 08, 2012 2:42 pm
Another "trick" is to use the axle shaft to pop the seal out.
Insert the tip of the axle shaft, behind the seal and pry it out.
PostPosted: Thu Mar 08, 2012 2:50 pm
Thanks Doc, I'll try that, too!
I must be over thinking this...
vm
vm
PostPosted: Tue Mar 13, 2012 5:29 pm
I used a small chisel to put a dent in the seal and relieve some of the pressure on the seat around the axle housing and then popped it out with the axle like Doc described.
Tony Bracamonte
'66 Dart GT
built /6 w/ garrett gt32
air-air intercooler
330 hp / 440 lbft @ 16.5 psi
