It is currently Mon Nov 16, 2026 5:33 am
PostPosted: Thu Mar 08, 2012 5:26 pm
could someone help me out with a picture of the rear main seal, and how it should sit in the block/cap.
i know about the oil pan article, ive read it like 100 times, but its been such a long day, and with my dyslexia im just having trouble figuring out exactly how it should go. id like to get the rear main cap on, and call it a night. and finish everything up another day. thanks!
PostPosted: Thu Mar 08, 2012 5:59 pm
6 Pack Dart
See this article
http://www.slantsix.org/articles/gasket ... n-seal.htm
Richard
PostPosted: Thu Mar 08, 2012 6:22 pm
maybe i should have mentioned that picture just looks like a black ring in the cap, i can see no grove or flat or angled. its not a very good picture, atleast on my laptop. i even tried messing with brightness and contrast.
PostPosted: Thu Mar 08, 2012 7:24 pm
6 Pack Dart
If you are using the "rubber seal" look at it you will see a lip on the inside of the curve, the edge (lip) goes toward the front of of the motor. You will notice the bolt heads will be visible if you look at the back end of the crank.
Richard
PostPosted: Thu Mar 08, 2012 8:16 pm
how bout this, does the part number on the felpro seal face the front or rear of the motor
PostPosted: Thu Mar 08, 2012 9:23 pm
6 Pack Dart
Look at the seal as a knife and put the cutting edge toward the front of the motor! :shrug:
Richard
PostPosted: Thu Mar 08, 2012 9:46 pm
that makes absolutely no sense to me.. sorry
how bout this.
someone sends me a pic, weather it be a standard pic with a arrow pointed to a side in Paint.. i am just not seeing the picture reading what you are posting. i dont understand how the seal has a "sharp edge" compared to the other side
PostPosted: Thu Mar 08, 2012 11:08 pm
6 Pack Dart
This is NOT a slant six seal but you can see what is needed.
Richard
PostPosted: Fri Mar 09, 2012 7:51 am
you never said which way the side the arrow is pointing to should be facing.
this will make it easy, today is a new day, im a bit more refreshed and i think i understand now.
is this correct?
PostPosted: Fri Mar 09, 2012 9:18 am
6 Pack Dart
Toward the front of the motor. In your picture it looks like you cut off part of the seal. The seal should fill all of the groove Do Not cut any off.
Richard
PostPosted: Fri Mar 09, 2012 9:36 am
It's sitting offset in the cap. Didn't cut anything. But is my picture correct?
PostPosted: Fri Mar 09, 2012 9:37 am
PostPosted: Fri Mar 09, 2012 9:50 am
Yes, that is correct. Make sure the upper half of the seal is installed the same way. The lip points towards the oil and pressure in the crankcase forces the lip into contact with the crank. If the seal is in backwards crankcase pressure will push the seal lip away from the crank.
PostPosted: Fri Mar 09, 2012 10:30 am
6 Pack Dart
The seal should fit all the way in the groove, if not you will have a gap and a large oil leak. This is a old rope style seal in place, the new rubber style should fill the groove the same way.
Richard
PostPosted: Fri Mar 09, 2012 10:56 am
It's OK to give the 2 seal halves a little off-set, just so all the parting lines do not line-up... but no "trimming" allowed on the molded rubber seal inserts.
