It is currently Thu May 21, 2026 3:49 pm
 Post subject: gas pedal linkage
PostPosted: Wed Apr 04, 2012 11:56 am
will this work. its for a V8 Barracuda. look: http://www.ebay.com/itm/63-64-65-66-Bar ... 169wt_1151
PostPosted: Wed Apr 04, 2012 12:25 pm
We still do not know the details of you application so it's hard to say if that item will work for you.
 Post subject: application
PostPosted: Wed Apr 04, 2012 3:34 pm
stock slant, 1bb carter, with rod application. too sloppy. 63 plymouth signet valiant, pushbutton 3 speed.
PostPosted: Wed Apr 04, 2012 3:47 pm
It sounds like you have all the parts but need to replace the "bushings & insulator" pieces to get the positive action back.
Usually the Insulator, at the carb is the reason for loosness in this linkage system. (14-11-30)
PostPosted: Wed Apr 04, 2012 4:36 pm
You can get replacement bushings from Gary Goers; see here.
 Post subject: parts
PostPosted: Fri Apr 06, 2012 9:14 am
I actually need the shaft. and Insulator. Dan will Gary have these ?
PostPosted: Fri Apr 06, 2012 9:26 am
Insulator yes, shaft no. The shaft usually doesn't break or fail, what happened to yours?
PostPosted: Fri Apr 06, 2012 12:11 pm
I have a used shaft, if needed... shoot me a PM.
PostPosted: Fri Apr 06, 2012 9:48 pm
I have a shaft (several) too.
PostPosted: Sat Apr 07, 2012 4:56 pm
Is the shaft the same between 170 and 225? I was wondering if there is a slight length difference due to block height.
PostPosted: Sat Apr 07, 2012 8:27 pm
Different rod from accelerator pedal to bell crank and from bell crank to carb for 170 vs. 225 engines.
