It is currently Sun Jun 14, 2026 12:15 pm
PostPosted: Fri Apr 20, 2012 8:54 pm
My dad just picked up a slant six and trans that is bolted to a skid. He says the guy used it to run a sawmill. It has a very odd manual transmission bolted to it. We're not sure if it's a car trans or something different. So I'm asking the collective wisdom here.
The bell housing has multiple bolt patterns.
The starter looks odd.
There appears to be a speedo-cable attachment.
There is a band brake on the end and a really odd driveshaft connection.
Also, the carb has some weird stuff going on. Is there anything special about the engine?
Here's a link to all the pictures:
https://picasaweb.google.com/1067010552 ... directlink
Thanks for any help you can provide. We're hoping to turn it into an engine test stand.
David Belau
1966 Dodge Dart GT IRS SOLD
1967 Plymouth Barracuda
http://dartslantsix.wordpress.com/
 Post subject: Welll...
PostPosted: Fri Apr 20, 2012 9:28 pm
The bellhousing is definately one of the early-60's low mount starter units for the larger flywheel with the 11" clutch...the low mount starter looks like the 3 bolt unit used in the early 60's (these weigh a ton compared to the newer reduction gear starters)
PostPosted: Fri Apr 20, 2012 10:14 pm
No 3-bolt starters on slant-6s in passenger cars or trucks. The '60-'61 cars used any of four heavy Prestolite (called "Auto-Lite" at the time) MDT direct-drive starters differing only in minor detail, but all of them were 2-bolt. These photos show a Prestolite starter, not the same as the '60-'61 unit, typical of marine and some industrial Slant-6s. Also, the carburetor is for a clamp-band type air cleaner attachment, but the choke is automatic, which is a somewhat but not entirely weird combination.
PostPosted: Fri Apr 20, 2012 10:31 pm
Looks like an A745 3-speed for a truck which would explain the band parking brake. It also appears the carburetor has a governor underneath it which was common on fleet vehicles of this vintage. You already noticed the bellhousing which fits the slant and the A/LA V8. Nothing too odd, just not as common as the lighter duty passenger car stuff.
PostPosted: Sat Apr 21, 2012 7:53 am
Thanks for the info. After a google search I think it is the 3-speed. The bell housing having both patterns will be nice so we can mount an LA engine to it as well.
Thanks again for the help!
David Belau
