It is currently Sat Nov 21, 2026 4:44 pm
 Post subject: start problem
PostPosted: Sat Apr 28, 2012 1:33 pm
83 D-150 slanted, engine started normally...died would not re-start there is only a click at the turn of the key.
Replaced starter with a known good starter...just a click
Replaced starter relay...just a click
Need your valued input, thanks
robert
PostPosted: Sat Apr 28, 2012 2:04 pm
Contributor
My guesses in order of probability...dirty connections at the battery...dead cell in the battery...internally corroded battery cable...loose ground connection.
PostPosted: Sat Apr 28, 2012 7:25 pm
Yup, battery connections, ground to block should be cleaned, and the battery its self can be good one moment, and dead enough to not turn over the engine the next start.
PostPosted: Sat Apr 28, 2012 10:29 pm
Battery cables do rot out after 30 years and will not carry enough amperage to kick the starter over.....
Ask me how I know......then why it rotted out 10" from the starter....
PostPosted: Sun Apr 29, 2012 7:12 am
Thanks Boys, today is already car care day and I will check the connections and cables, I thought that I had pretty much covered the bases, it's the simple stuff that gets me ,at least when it's not the other stuff.I will let y'all know how it goes.
robert
Users browsing this forum: Amazon [Bot], Bing [Bot] and 5 guests
