It is currently Sat Nov 21, 2026 5:57 pm
 Post subject: Piston question
PostPosted: Sun Apr 29, 2012 9:38 pm
Are the old TRW 12xx pistons 1.740 or 1.760 compression height? Thinking about using the 1.740 height pistons instead.
What camshaft spec. should I look at when considering the compression height, I know there is a chart when considering dynamic comp. ratio.
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Mon Apr 30, 2012 3:58 am
The ones I have on the bench, measure 1.754
Why would you want to use a 1.740 piston? That will lower the CR.
PostPosted: Mon Apr 30, 2012 3:51 pm
I had cc'd the heads and they will be equalized to 51.5 (Previous build) and from a stand point of longevity, the lower toward the pin, the less scuffing.
Thats why I was interested in learning what cam spec. to seek out, if I could urk out a little performance on that end.
Street performance for this one (225) but on my 170 I want some rpm and maybe turbo so am thinking same for pistons but lower CR with that so I can run higher boost with more cylinder volume.
