It is currently Tue Dec 23, 2025 3:12 pm
 Post subject: Proper line size?
PostPosted: Sat May 05, 2012 1:46 pm
Car Model: 1964 Dart 270
What is the size of the line (Diameter) from the master cylinder to the proportioning valve on a 1964 Dodge Dart? And anyone knows the length you get to bend it out of?
Thanks
PostPosted: Mon May 07, 2012 9:41 am
i have a 70 and it was 3/16 line, you could get away with a foot or 16" if you put a loop in it. also, the master cylinder fitting is a bigger size than the 3/8 one it comes with. i'd suggest finding the right fitting and flaring (double) the line and doing it right. i bought mine at a local auto parts store (i ended up just buying the spool, $25 i believe).
70 Plymouth Valiant 4dr
PostPosted: Mon May 07, 2012 10:47 am
Thanks for the info I need yo replace my master cylinder and want to replace the line they look.like the original parts and I want the replacement to look original ............
PostPosted: Mon May 07, 2012 11:53 am
The "single pot" systems used a 1/4 tube size leading down to the metering block.
Be careful with the fittings that come on pre-made hard lines these days, some of those do not fully seat in the fitting on the master cylinder.
PostPosted: Tue May 08, 2012 5:17 am
Thanks tor the info about the single pot system that is it for sure ...............
