It is currently Sat Aug 15, 2026 10:24 am
Post new topic  Reply to topic  [ 130 posts ]  Go to page Previous 1 2 3 4 59 Next
PostPosted: Wed Mar 21, 2012 9:40 pm
Kevin the starter is a mid 90s Durango mini the neg terminal is different it has a stab in style connector I just used a butt splice on the end and it slides over the post
ill post some pics with the new Turbo and waste gate attached tomorrow
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Thu Mar 22, 2012 6:10 pm
Here a couple mock up pics of the new setup
PostPosted: Fri Mar 23, 2012 6:22 am
LOOKING GOOD!!
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Mar 23, 2012 7:51 am
Looks great, what did you use to make the manifold ?? BTW SOOOOOOO jealous of that heated intake lol !!!!!
-Mike
PostPosted: Fri Mar 23, 2012 10:38 am
Sweet work.
PostPosted: Fri Mar 23, 2012 11:58 am
-Mike
Mike I used 304 stainless steel butt weld ells there about 3/16 thick. Also the flanges are SS as is the 6 to 1 merge collector. That intake is a nice piece I traded a new set of headers for it. I love the fact it has the bosses at the end of the runners so if in the future I decide to go EFI I could.
Thanks Aaron
PostPosted: Sat Mar 24, 2012 9:48 pm
Nice work, Aaron.
Could you please go through this thread from the start, and update the photo links, if you still have the pics?
Olaf
Aspenized
PostPosted: Sat Mar 24, 2012 10:08 pm
Nice work, Aaron.
Olaf
Olaf ill work on it in the next couple days thanks for the interest
Aaron
PostPosted: Sun Mar 25, 2012 5:16 am
Very nice. :D :D :D :D
PostPosted: Tue Mar 27, 2012 3:42 pm
Looking good!
Tony Bracamonte
'66 Dart GT
built /6 w/ garrett gt32
air-air intercooler
330 hp / 440 lbft @ 16.5 psi
PostPosted: Wed Mar 28, 2012 2:54 pm
I may have missed this info, but what size turbo is that? cool a durango starter hmmm is that about the size of a mini starter or those mini's still smaller than that?
Kev
PostPosted: Wed Mar 28, 2012 4:07 pm
Kevin the Turbo is a turbinetics T60-1 60mm cold side.68mm exhaust side as for the mini looks like one I had on a big block 67 cuda in the 90's our then the different negative connects
Here's a couple pics Im installing some frame connector there all tacked in and just awaiting the final welding
 Post subject: 5/6/2012
PostPosted: Sun May 06, 2012 12:17 am
Here's a couple pics of the new setup with the motor and transmission installed
I hoping by the end of next week I should be ready to fire it back up
Aaron
PostPosted: Sun May 06, 2012 6:25 am
Car Model: Road Runner
Very cool. Where did you get the flanges to build the exhaust?
PostPosted: Wed May 09, 2012 12:58 am
Dan O the flanges I bought of ebag there's a guy that sells them but every now and then you can find a pair of them in a auction and there Alot cheaper I think I paid around 20 bucks for stainless ones which the guy I'm referring about sells the stainless ones for around 90 bucks
The header cost me around $400 bucks to make but I'd have to say probably about 60 hours to fab up and weld it was a very time consuming task but I'd I'm very happy with how it turned out
I'm about ready to start it back up I was trying to flush the gas tank out two days ago and my fuel pump took a $#!+ on me so I had to order a new one but it should be here by the end of the week which isn't a problem it's given me some time to plumb in my water lines for the turbo and the intake also the trans to the trans cooler
I'll post some updates this weekend
Aaron
