It is currently Mon Oct 12, 2026 11:07 pm
PostPosted: Fri May 11, 2012 9:35 pm
Hi all, I need help with figuring out what stall speed converter to go with for my A-904 TF. My 225 will be a street/strip engine around 10.5:1 comp, custom grind solid cam with 244/252 @ .050", and various other parts to match. Plan on runnning 3.73 gears in my 741 case 8 3/4. Trans will be pro-built as well. This is all in a '63 B-body too :lol:
Hoping this is enough data to get some ideas?
www.CP-Carrillo.com mlozano@cp-carrillo.com
PostPosted: Fri May 11, 2012 9:58 pm
Car Model: 64 Valiant
Any idea on what the weight will be?
PostPosted: Fri May 11, 2012 10:29 pm
Still some time out from having the car weighed. Rough guess is around 3,500-3,600 lbs ?
PostPosted: Fri May 11, 2012 10:34 pm
A lot of guys here are using 3000-3500 RPM converters. Looks like your going to be pushing a lot of weight, so I would start there unless others have some recommendations. What's "Snake" doin' these days....
PostPosted: Sat May 12, 2012 12:12 am
.Thanks for the advice on the stall speed, I'll most likely be looking in that direction then.
"Snake" is still very busy being the VP os sales here @ work CP-Carrillo. He's a very good guy to work for :D . Have you bought pistons from him in the past?
PostPosted: Sat May 12, 2012 12:32 am
Yeah, when he was at JE. They had some awesome nitrous forgings that I used in all my stuff.
PostPosted: Sat May 12, 2012 12:48 pm
Just give me a call @ work when ever you need some piston or connecting rod stuff! Just remind me that we spoke on this forum when you do call. :lol:
PostPosted: Sat May 12, 2012 6:11 pm
Thanks, I'll give you a shout at the first of the week.
PostPosted: Sun May 13, 2012 4:09 am
Assuming this is mostly a drag car, with some limited street use, I'd say go for around 3400-3600 stall. 9.5" converter diam. If you want more heavy street use, then 2800-3000 will also work well. You will have to talk to a reliable converter place and specify your engine est output, or they will sell you a V8 unit that will stall much lower on your car.
I have run both these stall speed ranges on the street and have been happy with street and strip use. To go higher than about 3600-3800 stall, you will need quite a wild 225 to make the high revs.
PostPosted: Mon May 14, 2012 7:41 am
Hi Lou,
Thanks for the recomendation. Your expoirence is definately valued! I for sure will call & talk to one of the major trans/converter shops to fine tune my disicion.
The car will will be mostly for drag race/limited street use.
PostPosted: Mon May 14, 2012 8:18 am
My feelings about conv places...
Best conv places that I've used:
Midwest Converters (Rockford, IL)
Continental Converters (Inglewood)
Edge Racing Converters (SoCal somewhere)
Maybes:
PTC (GA)
Hughes (AZ?)
Best, Lou
PostPosted: Mon May 14, 2012 8:19 am
+1 for Edge .....
PostPosted: Mon May 14, 2012 12:59 pm
I'm familiar with Continental & Hughes. I think we have a connection with Hughes through work. Thanks!
Users browsing this forum: No registered users and 32 guests
