It is currently Thu Dec 25, 2025 9:05 pm
Post new topic  Reply to topic  [ 1294 posts ]  Go to page Previous 143 44 45 46 4787 Next
PostPosted: Mon Apr 23, 2012 9:14 am
Rick, By Front - I am assumming you mean the airdam?
Yes it that shot it's up.. It is adjustable between 1.5- 7~8" At mason dixon when you saw the car It was real low and was tripping the staging beams - THen it got all ripped up on the return road & by my tow strap when I winched it up onto the trailer.
I rebuilt the support to be more stable and I was setting it for 4" so I didnt hit stuff on the return road...as much.
In that pic I had just got off the trailer and Was returning from tech so it was still up quite high - THen I set it for 4" for the actual runs..
PostPosted: Tue Apr 24, 2012 6:49 am
wondering where you have your driveshaft loop
do you think if you had one mounted up front and one in the rear it would have done the damage to the transmission
also what did it feel like. did it fail @ a shift point ?
did you know @ 1st what happened or ?
slant six's RULE!
http://www.usajon.com
 Post subject: 4-29-12
PostPosted: Sun Apr 29, 2012 2:22 pm
@usajon. I don't know if using 2 loops would have saved The trans
I can't see how it would hurt except adding weight.
The car just went a 12.43 @Pittsburgh in normal air. I tried a 750 Carb. And picked up .16
More info to follow
PostPosted: Wed May 02, 2012 2:34 pm
Well On Sunday I Made 4 runs..
Two runs on the ole' trusty Carter/ Edlebrock 500CFM AFB
And Two On a differnet Carter / Edelbrock 750 CFM AFB - The 750 Picked up almost .2 in identical conditions..
See Time slips Below - I think the "green" PTC Converter (which Is in Alabama Now @ PTC Being "freshened") Combined with a 750 carb of some sort might get Ruster very close to the 11's.
Video is Of Run 3 - Unfortunately I did not get a back up run on # 4 - The park Gear / Governor Spacer Worked it's way off the tailshaft causing A "no shift / No park Issue - I am fixing this now :-)
PostPosted: Fri May 18, 2012 2:39 am
Last Night Was very Productive - Air Was great.. Pressure went up to 30.76" by the end of the Night
I ran a 12.30@107 then backed it up with a 12.24@108.
Video HERE!
Ruster likes the 750 carb, and Is wanting more jet.. But that will wait until the next TNT.. And this is with the "slow 60' times Midwest Converter" I did recieve my PTC converter back from PTC... It's refreshed and has a new pump drive in it. Tim @ PTC said " this thing is the highest stall possible.." which is great.
I cant wait to get to Mason dixon and then in a few weeks to stab in the other PTC converter.. 11's are getting closer!
Also I seem to have worked out the Park gear / Governor spacer "pop off issue" so that's good news too.. Lou Is supposed to bring Some scales to Mason dixon so we can get a new accurate weight on Ruster. YAY!
Lets race!
PostPosted: Fri May 18, 2012 3:20 am
Awesome!
PostPosted: Mon May 21, 2012 4:13 am
While at mason Dixon over the weekend, Lou Was Nice enough to bring his 4 corner scales.. We found a reasonably level pad to do some weigh in's
I think that we had weighed about 6-7 cars after all said & done..
Ruster's actual weight with a full cell of fuel is pretty close to my calculations..
I calculated that it weighed 2190.. and Actual was 2193.
Now I have to install the New alternator and work out the bugs with the mount up.
PostPosted: Wed May 23, 2012 5:21 pm
that nice to see, alot of people told me a 750cfm is too big! on my mild engine at 3000lbs i ran a 14.20et and my higher compression engine at 2500lbs i ran 12.30et. that was after running a 600cfm, keep up the good work.
PostPosted: Fri May 25, 2012 7:36 am
SL6 Racer
Do you have the front /rear totals and rt/left numbers. i would suspect its 55% front ,.
PostPosted: Fri May 25, 2012 11:33 am
I could loan you my drivetrain to see how fast it would go in a car that weighs 1,100lbs less!!
Nice job Greg.
11.02 @ 120.56
Chassis dyno
PostPosted: Fri May 25, 2012 7:39 pm
@ Sergio..
Yes Front 1263# 57.6%
Rear 931# 42.4%
LF 661
RF600
LR 411
RR 520
Weight Distrubition Not ideal at all for now.. Motor plate and Moving Engine / Trans rearward 6-12" is in the future sometime :-)
@ Tom -
I predict your Power in my car is unsafe w/o a cage and it will go Mid 9's!
PostPosted: Wed Jun 06, 2012 6:21 pm
Looking good...was just cruising through your posts and found the awesome picture of the Amsoil Super Shift!! I am proud! There are some fast slants running it in the trans including yours.
Tom's idea would be fun also. Any plans for a turbo?
Later
Ryan
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Fri Jun 08, 2012 7:18 pm
Later
Ryan
Hi Ryan, I figured I would the try The Amsoil.. I know that makes you proud.
I was running Type F before. Non Synthetic, I believe.
The turbo Idea is waay cool.. but in my chassis just plain scary at this point.
I would Megasquirt it first then get the Block o ringed, either get a really thick head gasket or another unmilled head, and Then the cam and turbo..
I want to Turbo my street car First.. Have The Biggies laying around the shop to do it (Old GN Turbo, Intercooler, Car Laready Had Dutra Duals) but Just need to get motivated to start such a project..(once my flywheel comes in from McLeod I will have the Correct Parts to get turbo power to the trans!)
PostPosted: Tue Jul 31, 2012 1:34 pm
Well I picked up a Holley 4150HP 750 CFM carb at Carlisle for a steal....
So I am going from a 750 Carter AFB to A 750 Holley 4150... I think the holley will be better (quicker) on the big end..
Also My second hand slicks are getting tired after 3 years of racin..
They were 27X10.5-15 quick time pro's - they had 2 cheater treads and were a DOT tire..
I couldnt find a real drag slick in that size.. so I opted for a bit bigger.. 28X10 D06 Compound Hoosiers.. They are an inch taller which required more rear fender well Hacking..
Maybe I lost 1/2 a pound but off the rear of the car :-(
Third time for rear wheel well enlargement.
New Sick is in the back.. it's a bit bigger.
PostPosted: Tue Jul 31, 2012 2:33 pm
What was the masking tape for? :wink:
