It is currently Fri Jun 05, 2026 3:07 am
 Post subject: fuel boil?
PostPosted: Tue May 22, 2012 12:03 am
My car starts fine cold but if it's warmed up its harder to start and stumbles a little. Once I start going down the road it lags a little and then it fine again.
It has had the valve lash done, timing is set at 8 btc . I don't know the idle speed...I should get a tach!
1970 Dodge Dart Custom w/ 1bbl slant six
PostPosted: Tue May 22, 2012 5:28 am
Have you done Dans fuel line mod yet? Had the same problems with my Satellite and after doing the mod, problems went away. It could also be a float set to high.
PostPosted: Tue May 22, 2012 6:31 pm
Car Model: '63 Dart GT Convertible
My 74 Duster did the same. Fuel line ran in front of the head and close to the exhaust, I covered it with a piece of split heater hose, all was good. Nothing is so permanent as a temporary fix.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Tue May 22, 2012 6:49 pm
Do the Fuel line mod.
PostPosted: Wed May 23, 2012 9:22 pm
Ok dan,will do! I had been planning on it and had already read your link before. Just wanted to make sure that sounded like the right solution to my problem. :)
Users browsing this forum: Google [Bot] and 8 guests
