It is currently Fri Apr 24, 2026 7:25 am
 Post subject: rear-end question
PostPosted: Fri Oct 24, 2003 4:35 pm
I have a 8-3/4 rear that I want to install in my 66 dart. The length from backing plate to backing plate is the same. But the perches that are welded to the housing are several inches off. Which blowes away my original theory of it coming from an A-body car.
Now my question-Can I take the housing to a welding shop and have them cut the perches off, and then reweld them back on. Actually I will weld them on, I just want make sure I should reuse them?? Probably a stupid question, but hey, whatta ya want?? :roll: :oops:
Hellbent Rods & Custom fabs
PostPosted: Tue Jan 06, 2004 11:56 am
did you get your 8 3/4 mounted in the Dart? One thing you really want to be sure of when removing, moving, and re-welding the perches, is that you make d...mn sure you get the angle of the dangle correct, otherwise you will have a vabration and not know where to look. If off just a couple of degrees in angle, it could mean vibration. Unpleasant for sure.
'56 Chrysler New Yorker St. Regis 354
'63 Plymouth 426 Max Wedge "NoMo-Par?"
'63 Plymouth Valiant 225 Hyper-Pak Wannabe
'68 Plymouth GTX 440
'70 Dodge Charger 500 440
'71 Dodge Demon 225
'71 Dodge Charger Super Bee 383
