It is currently Thu Nov 26, 2026 6:58 am
 Post subject: Carb question
PostPosted: Thu May 31, 2012 1:08 pm
I plan on fixing my /6 and want a carb with more cfm, can I adapt a Ford 2 or 1 bbl carb ,used on 300cid engines, on my six?
After the next world war only two things will be running around .... cockroaches and Dodge pickups!!
PostPosted: Thu May 31, 2012 1:11 pm
Yes. See HERE.
PostPosted: Thu May 31, 2012 2:26 pm
There would be no point adapting a 1bbl from a Ford. They are about the same size as the 1bbls used on the slant-6; you'd have adaptation hassles for no benefit.
A 2bbl carburetor is a popular upgrade. There are many ways to do it, and there are many different 2bbl intake manifolds. There is also the option of custom-modifying a 1bbl intake manifold to accept a 2bbl carburetor; for example, See the parallel 2bbl setup article. Photo documentation of a very well done such conversion is here.
There are adaptors that will let you mount a 2bbl carburetor on a 1bbl intake manifold. These are dumb; don't waste your time, money, or effort.
If you'll provide more specifics about your vehicle and engine and how you intend to use it and what you want it to do, more specific and helpful recommendations can be made.
PostPosted: Thu May 31, 2012 2:30 pm
I never said it was a good idea, I just said you could. :wink:
PostPosted: Fri Jun 01, 2012 4:21 pm
some pics of mine..... Autolite 2100....modified aluminum 1 barrell intake
And a little video
http://s1202.photobucket.com/albums/bb3 ... 131806.mp4
And another
http://s1202.photobucket.com/albums/bb3 ... 131802.mp4
One more
http://s1202.photobucket.com/albums/bb3 ... 131804.mp4
crossthreads are better than locktite
