It is currently Sat Nov 21, 2026 11:05 pm
PostPosted: Sat Oct 25, 2003 5:02 pm
My 71 manual states, for all drums and floating caliper & drum system, to start with rear wheels and move to front. For fixed (4 piston) caliper & drum, to start with the front and move to the rear.
Any ideas? I have the 4 piston setup, and started with the rears as I have known was generally proper, but my pedal still sinks a bit on the first pump compared to subsequent pumps. Wonder if bleeding the fronts first will make a difference?
PostPosted: Mon Oct 27, 2003 1:21 pm
Give it a try, I do know that the K.H. 4 piston caliper is pretty high and any air will end-up there.
With the Discs, most of the pressure is set forward so that may be why they want you to bleed the fronts first.
 Post subject: Brake bleeding tricks
PostPosted: Mon Oct 27, 2003 3:50 pm
My favorite way to bleed brakes is to use Speedbleeder one-way valves. These things replace the usual bleeder screws, and I've found I can get a lot more air out using these things than with conventional brake bleeding techniques.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Oct 27, 2003 3:55 pm
Matt, yep I put in speedbleeders all around. They do work well, just must be careful because three pumps of pedal with one open bleeder and the resevoiur is drained.
