It is currently Wed Jul 15, 2026 4:07 pm
 Post subject: Valve spring question
PostPosted: Thu Jun 14, 2012 4:27 pm
Has anyone ever run the Mopar 528 lift cam with 340 valve springs? Did they have enough pressure? What about coil bind? Or did you have to run dual springs?
I have several sets of 340 springs, but no dual springs. I am going to try that cam, but I am being myself..............."FRUGAL" :lol:
PostPosted: Thu Jun 14, 2012 5:57 pm
I wasn't brave enough to try it Charlie. Mike did not put double spings on mine, but we did move up from the 340 springs. IIRC, the .528 cam is just a touch over what Mike felt safe with 340 springs. They are good for roughly .500 gross lift.
PostPosted: Thu Jun 14, 2012 6:49 pm
With valve lash you are pretty close to .500 anyway. It may be something to give a try. Then you can let us know how it works Charlie!! :lol: :lol:
PostPosted: Thu Jun 14, 2012 7:14 pm
I'm thinking the 340 springs are marginal. If it was a 225 and only turning a max of 6,000 rpm, I would probably try the 340 springs. This is a 170 and will be turning close to 7,000 rpm, so I guess I will have to bite the bullet, and buy some springs. Will have to wait for a little while, till the budget allows. Meanwhile I will cut the guides for seals, do a little grinding on the pushrod holes (late style head, and the 3/8 pushrods are rubbing). Maybe even put in some MP over size valves, with pocket porting. This would all be free labor (mine :lol:)
PostPosted: Fri Jun 15, 2012 6:45 am
Coil bind is the issue. These do not look good to me.
PostPosted: Fri Jun 15, 2012 7:04 am
Yep. I'm thinking, "penny wise and pound foolish". There is a difference between "frugal" and "cheap". I will just wait a little bit and get a better spring for the application. Anyone have a deal on some springs?
PostPosted: Sun Jun 17, 2012 9:22 pm
run these...
http://www.summitracing.com/parts/CRN-99839-16/
they will give you a good 300 open pressure 130 seat...
something to remember to is Lift(- lash) + .050 clearance + coil bind = installed height...
these will give you the pressure and with .020 shim or so (on a 1.7 stock installed height) should have you set...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
