It is currently Thu May 28, 2026 12:19 am
PostPosted: Mon Jun 02, 2003 2:00 pm
A long, long time ago, in the Beforetimes, Doug Dutra wrote an article containing a Ford part number for a replacement float (only) to fix leaky fuel gauge tank sender units. I can't find the P/N. Anyone still got?
PostPosted: Mon Jun 02, 2003 4:43 pm
Dang, I have that issue! To bad its buried in the black hole known as my storage unit. If it helps any, I believe its the issue featuring the A100 vans and trucks. Doug did an artical on 25 cheap up-grade tips in that issue. Sadly, that artical didn't help me much (B body owner). :lol:
PostPosted: Mon Jun 02, 2003 6:13 pm
The part number is located in the parts data base. Ford COAZ-9202-B
PostPosted: Tue Jun 03, 2003 12:51 am
It's in the parts database. Use the Parts List link on the main page and search for "float"'
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Mon May 07, 2012 11:23 am
Ford seems to have lost their minds on fuel sender floats. One dealer near me wanted $17 another wanted $19.
I found mine at Auto Krafters, P/N 15309, for $6.95/$11 and change with shipping:
http://tinyurl.com/7cpcn6h
My old one is still rattling around in the tank behind the seat where I dropped it along with a fish net I was trying to retrieve it with. One day I'll get time to remove the tank and dump them both out.
Danny
PostPosted: Tue May 08, 2012 9:45 am
Last time I purchased this item at a F@%$ dealer I also had "sticker shock" but then realized that the price was for a package with 2 floats in it.
I wonder if they still come 2 per box??
PostPosted: Tue May 08, 2012 10:41 am
I bought the float at the ford dealer a couple years ago. I recall it being about $12 for one. If I'm not mistaken, the sock comes from GM right?
PostPosted: Tue May 08, 2012 11:08 am
I didn't ask but that may be the problem. I don't think any of them checked but look up the part number on the computer - didn't mention it being a package of 2.
Unless you need 2 the one from Auto Krafters works fine and looks exactly the same. The package even has a Ford logo on it and says "Official Liscensed Product" on it. Made of brass.
Danny
PostPosted: Tue May 08, 2012 11:09 am
Float: Ford P/N COAZ-9202-B
Strainer "sock": GM P/N 5651 705
Gasket: Chrysler P/N 6031 475
Sender grounding clip: Chrysler P/N 2258 862
PostPosted: Tue May 08, 2012 10:44 pm
Thanks Dan! I added your entries to the Parts database.
PostPosted: Fri Jun 29, 2012 10:55 am
My gas gauge ('63 Dart 170) doesn't work. Will I need all of these to fix it?
'63 Dodge Dart 170
PostPosted: Fri Jun 29, 2012 1:16 pm
You'll need to do some diagnosis to find out what's causing the problem. It could be a dead sender, but it could also be the sender's fine and just the float has sunk, or it could be a missing ground at the sender, or it could be a dead fuel gauge itself, or it could be a wiring problem.
Get the three books described in this thread as quickly as you can; they are the very first tools to buy when learning how to fix your car.
PostPosted: Fri Jun 29, 2012 4:04 pm
Thanks!
'63 Dodge Dart 170
PostPosted: Fri Jun 29, 2012 4:14 pm
Seriously, thank you, Dan. This is the info I've been needing. When I was in school, they didn't allow girls to take shop (believe me, I tried), so I've got a lot of catch up to do.
'63 Dodge Dart 170
PostPosted: Fri Jun 29, 2012 4:29 pm
Sure thing, glad to help.
There was a girl in my 9th-grade English class who is probably still better than I am at rebuilding engines. And I'm a better cook than some women I know. The best revenge against small-minded bigots who issue rules like "Girls can't take shop" is to do exactly what you're doing: learn it anyhow.
