It is currently Sun Nov 29, 2026 5:08 pm
 Post subject: Replacing 225
PostPosted: Tue Jul 17, 2012 2:13 pm
Just picked up a rebuilt 225 and the price was great .
I was wondering about the freeze plugs. My original
engine has 3 and the rebuilt has 5. Im sure its a later model
cause the original id starts off with 24 and the other is 28.
Since I bought my 63 my guitar
has taken the back seat.
PostPosted: Tue Jul 17, 2012 6:42 pm
68 and up have a larger end on crank ...both inside and outside dia. bigger then 67 and earlier
PostPosted: Tue Jul 17, 2012 9:31 pm
What kind of vehicle are you putting this engine in? Year, model, and transmission type?
PostPosted: Wed Jul 18, 2012 10:20 am
Its going into a 63 Polara and just before I came in here I just figured
out that that end is bigger than mine .Are they pressed in or is this something I could get at auto parts store or do I have to get it milled?
PostPosted: Wed Jul 18, 2012 10:38 am
The trans is automatic and I believe its a torqueflight
PostPosted: Wed Jul 18, 2012 10:57 am
If it's a 904 automatic, you will need the later flex plate (large center hole) and the special adapter ring to press into the end of the cranlkshaft.
(I have the adapter rings, if you need one)
PostPosted: Fri Jul 20, 2012 1:45 pm
Thanks guys had my original milled for forty bucks and bolted
trans right up. Gotta tell you mounting a slant six is a pain in the dipstick
I fought all day trying different chain angles.Then again Im half crazy
thinking I could sweep away the gravel in driveway and lay some
plywood down .
PostPosted: Fri Jul 20, 2012 2:27 pm
Gulp....
So it sounds like you had someone machine-open the center hole of your current flexplate and did not use an adapter bushing to support the front of the converter... correct?
 Post subject: Yikes!
PostPosted: Fri Jul 20, 2012 6:29 pm
:shock:
PostPosted: Sat Jul 21, 2012 10:41 am
What I did was have them machine the adapter bushing and everything went into place.
PostPosted: Sat Jul 21, 2012 11:20 am
So day 2 of trying to mount this engine and come to find out that
the oil pans are different !!!!!!
The original engine is a 1966 , the id is 2463430-13
The engine im trying to mount ? the id is 2806830-4
Will this work if I take original oil pan off and put on the new engine?
Its going in a 63 Polara . The engine im trying to mount ,there is a
number on the oil pan which is 285 , my original engine oil pan has no
number. :x
PostPosted: Sat Jul 21, 2012 11:28 am
I failed to say that the new engine oil pan is hitting the K Member as I
swing the engine down to line up passenger side motor mount , the driver side mount is lined up only because I noticed a difference and put my
original one on . Gotta love surprises it builds character :P
PostPosted: Sat Jul 21, 2012 11:49 am
This engine came out of a 66 Belvedere , is the K member different ,
body longer than my 63 Polara , maybe I should have completed
that physics class .
PostPosted: Sat Jul 21, 2012 1:25 pm
Swap the oil pan and pickup from your '63 engine onto the newer engine.
And yes, you'll need that transmission adaptor bushing if it's not already present.
PostPosted: Sun Jul 22, 2012 9:33 am
Thanks looks like it will work
