It is currently Thu Mar 13, 2025 8:27 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Aug 10, 2012 3:09 pm
Are you talking about a thick gasket/insulator or an actual heat shield?
Rick
I was actually wondering the same thing... :?
MRO....
PostPosted: Sat Aug 11, 2012 9:30 am
Yes that's what I'm asking about, The marine one is about 3/8" thick and the other is 1" thick.
[/img]
74 Dart Swinger, supersixed.
PostPosted: Sat Aug 11, 2012 9:37 am
Still no links or pics to the shields you bought, eh?
Thanks, I guess. :shrug:
PostPosted: Sat Aug 11, 2012 10:07 am
Hmmm guess not so your guess is as good as mine. BUT I will surmise that he is talking gaskets/insulator and not a true "shield"... :?
MRO....
PostPosted: Sat Aug 11, 2012 10:42 am
I'm going to guess he's talking about a grilled cheese sandwich cut in the form of a carb base gasket to serve the insulation function, with the rest of the sandwich (extending out from the carb flange) serving the heat shield function.
My guess is as good as yours until he stops being cagey and coy and shows us what the heck he found.
PostPosted: Sat Aug 11, 2012 12:00 pm
Sorry for the delay, here's a link I uploaded several pics to photobucket.
http://s1270.photobucket.com/albums/jj602/Szabo99/
PostPosted: Sat Aug 11, 2012 1:19 pm
Here are the two links.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... _654wt_689
http://www.ebay.com/itm/251106761373?ss ... _500wt_922
Curently I have the card mounted straight to the intake, I'm guessing the thick one would work better, let me know what you think.
PostPosted: Sat Aug 11, 2012 1:51 pm
I'm gonna go ahead and say spacers, not shields.
PostPosted: Sat Aug 11, 2012 1:58 pm
Phenolic spacer, not a heat shield. Although it is nice and tall and might help low RPM torque a bit.
PostPosted: Sat Aug 11, 2012 2:48 pm
Neither of those is a heat shield. The brown one is a custom/aftermarket item that is way too thick for most passenger car, truck, and van applications without throttle and choke and transmission linkage modifications, and even if you make those mods the odds are against your being able to close the hood once you've installed the air cleaner.
The black/grey one is just a standard production 3/8" thick insulating-type carb base gasket, the kind that's supposed to be there on just about every 2bbl slant-6 and V8.
I still think my grilled cheese idea has merit.
PostPosted: Sat Aug 11, 2012 3:02 pm
I still think my grilled cheese idea has merit.[/quote]
Mmmm grilled cheese.
You would probably have to stay clear of "American cheese" since I think it's made with petroleum bi-products. Could be a potential fire hazard.
PostPosted: Sun Aug 12, 2012 10:03 am
Thanks for the feedback, I will probably experiment with both if the mods are not to bad on the thicker insulater. Hood clearance is not an issue right now with the tiny air cleaner I am currently using.
PostPosted: Sun Aug 12, 2012 12:53 pm
Tiny air cleaner = more of the kinds of problems you're trying to solve with a heat shield.
PostPosted: Sun Aug 12, 2012 3:28 pm
At least get a 6 inch diameter air cleaner on that thing (10 would be better). Those itty bitty filters are a huge restriction.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Aug 12, 2012 3:55 pm
Use a factory air cleaner with a thermostatic snorkel. An air cleaner with an open/exposed element is not better, it's worse.
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
