It is currently Wed Aug 12, 2026 1:42 pm
PostPosted: Mon Aug 20, 2012 10:21 pm
http://www.enginebasics.com/Advanced%20 ... 0Test.html As soon as I saw this I thought about posting it up, with a bit more fine tuning it looks like might be a real winner for guys running a true twin scroll (ie the hx/hy 35 ) turbo soon to be like me lol let me know what you guys think,
-Mike
PostPosted: Mon Aug 20, 2012 10:45 pm
Kinda like a Variable Nozzle Turbocharger.
PostPosted: Mon Aug 20, 2012 11:44 pm
I think they run about 500 bucks but there's some videos on utube of guys that made there own
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Mon Aug 20, 2012 11:53 pm
As far as I know (have read on the internet), they do work pretty well.
I have no idea what I am talking about.
PostPosted: Tue Aug 21, 2012 12:37 am
There's some videos on utube and it appears you can run a larger turbo and get it to spool at lower rpm range. It's a sweet concept
PostPosted: Tue Aug 21, 2012 5:13 am
$500 ??!!!! haha no thank lol, the idea is crazy simple start with the initial cut of metal from inside make a cardboad template, bevel edges for a flusher fit, you can find sotck waste, and mod it IE gently cut the THE VERY TOP off, braze on a thick flange drill and tap some hole for a cover plate, and BAM now you can swap waste gate springs to adjust when it fully opens, hardest part would be drilling a hole STRAIGHT through the turbo exhaust housing.
Then which shouldered/collared bushing to pick, brass, bronze or stainless, I would think stainless in a app like this due to the heat,
-Mike
PostPosted: Tue Aug 21, 2012 3:35 pm
Looks like some of the stuff on the DD13 or DD15 Detroits.
