It is currently Fri Nov 29, 2024 5:56 pm
Post new topic  Reply to topic  [ 1275 posts ]  Go to page Previous 145 46 47 48 4985 Next
 Post subject: 9-21-12
PostPosted: Fri Sep 21, 2012 4:08 am
Well it's all back together and up on the trailer ready to hit TNT next week.
I have all 3 gears and no Leaks and it moves on it's own power..
I used Lots of Red loctite on the Flexplate & Converter bolts.
We shall see what it can do.
PostPosted: Fri Sep 21, 2012 6:09 am
Good luck with the new parts. It will be interesting to see it go, are you taping your runs?
Go Ruster go!!
Regards Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Fri Sep 21, 2012 7:02 am
Go Ruster go!!
Regards Derek
I try to.. It's sometimes hard to get a good Cameraman, but my dad is usually around and he is getting better with the Video.
When I go faster than 12.24 I will post it.
PostPosted: Fri Sep 21, 2012 8:06 am
Good luck Greg! :D :D :D :D
PostPosted: Fri Sep 21, 2012 8:45 am
Thanks Dennis.. do you have the blue car together yet?? I cant wait to hear about / see it run!
 Post subject: More Lightening 9-28-12
PostPosted: Fri Sep 28, 2012 2:48 pm
I got a lightweight steering wheel for ruster..
It weighs only 1.6#
The old stock wheel was 4.6#.. Weight savings of 3.01# off the drivers side front!
YAY
Pics:
old wheel @ 4.6#
New Wheel has lots of holes and is only 1.6#
Calculated weight of ruster is now under the 2190 mark.
2187.7#
PostPosted: Sat Sep 29, 2012 4:23 am
You have gone quite mad, you know... I love it.
PostPosted: Tue Oct 02, 2012 12:08 pm
Where did you get that thing!? :shock:
I like it! :D
PostPosted: Tue Oct 02, 2012 1:08 pm
I like it! :D
Summit Racing
http://www.summitracing.com/parts/LNG-56833/
I am going to see If I can get a local guy make the Steering rod out of AL Bar stock for me.
PostPosted: Wed Oct 03, 2012 5:33 am
I would use tubular DOM steel or CrMo tubular to make a steering shaft. Aluminum has much worse fatigue characteristics than steel, and a steering shaft is pretty important.
PostPosted: Wed Oct 03, 2012 6:59 am
Yeah, and a CrMo tube will probably be lighter. :D
PostPosted: Wed Oct 03, 2012 9:00 am
Good thoughts.. I Was not thing tubular I was thinking solid AL... But if I went with hollow CrMo 3/4" tube i could weld the stock ends to it and call it a day.
All in the name of getting closer to that 2000# weight with driver !
PostPosted: Wed Oct 03, 2012 2:03 pm
They sell hollow DOM tubing at Speedway Motors and places like that for just this purpose. I think you can even get a Mopar box/joint spline on one end.
PostPosted: Wed Oct 03, 2012 8:18 pm
A piece of .058 wall .75 diameter 4130 will work good. Check the Chassis suppliers for a 3 bolt steering wheel flange with a 3/4" hole. If you are going to use the stock steering box cut off the end of one with the splines on it and turn it down so it will plug into the end of your tube and weld it on. TIG You can make a steering colum out of aluminum tubing or just use a pillow block bearing on the shaft.
 Post subject: 4.86 Chunk Built
PostPosted: Sun Oct 07, 2012 6:50 pm
Well I think I am going to Order some 4130 tube from onlinemetals. com to make my under Dash bar and the Front down tubes.. All of the Bars are here for the Roll bar... I also am going to order some 4130 3/4" tube to replace my stering shaft. I will be adding all of that this winter :-)
I ordered an engine plate From Edd J.. Waiting to hear back from him on when it will ship..
I just got done finishing up a 4.86 Chunk... I will be trying that out in the spring. :-)
