It is currently Sun Oct 25, 2026 11:38 pm
Post new topic  Reply to topic  [ 171 posts ]  Go to page Previous 1 … 8 9 10 11 12 Next
PostPosted: Tue Oct 02, 2012 11:59 am
You guys better quit talkin' this up so much! It makes me want a nifty valve cover for Chase's Demonster... :lol:
PostPosted: Tue Oct 02, 2012 2:26 pm
UPS just delivered my valve cover and dual single manifold as well. Guess I better get cracking on fabricating another stovepipe for this one just like my other one.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Oct 02, 2012 7:58 pm
Car Model: '23 T-bucket
Rob....there's an extra voice in your head, now. It's a valve cover whispering "buy me, buy me". :lol: :wink:
Sidebar ! You guys that bought the 2x1 intake.....if you plan on mounting Holley 1920's, check your carb flange bolt pattern soonest. I wanted to use Holley 1904's, and the bolt pattern is smaller on the carb than it is on the manifold. I may be wrong, but I think the 1904 and 1920 uses the same flange pattern. I'm already in the planning stages of fabricating an adapter for this. (Also working on a water heat manifold for plenum heat, as I wanted to run headers.)
Roger
PostPosted: Thu Oct 04, 2012 7:26 am
Would you be interested in fabricating a stovepipe and baffles for mine? I would pay you for the time and materials. I really like the looks of the previous one you did and figured since you had already done it before you would probably be the expert.
Currently a 1976 /6 with no car to put it in, hoping to build a hot rod around it.
PostPosted: Thu Oct 04, 2012 7:36 am
Believe me, I'm no expert - just winged it. I just cut and formed the the sheet aluminum for the shape of the baffles and rolled the aluminum till I got the correct size for the PCV cap. I had someone else TIG the stovepipe together and TIG it as well as the baffles to the valve cover. I had them hole saw the valve cover since they were doing the other work. Anyway, drop me a PM.
PostPosted: Thu Oct 04, 2012 1:07 pm
Got my 4bbl intake in yesterday! Damn it's light compared to my original! :D
1970 Dodge Dart Custom w/ 1bbl slant six
PostPosted: Wed Oct 17, 2012 4:52 am
Poser
I assume everyone got their parts and things look good. I know my dual carb intake is looking mighty fine. Remember Dan might have a few extras if you were sittin' on the fence. Thanks to Dan and the rest of you guys for making another group buy a success.
PostPosted: Wed Oct 17, 2012 2:50 pm
dmarv, P.M. sent.
ATB
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Thu Oct 18, 2012 3:07 am
Quick question,
Will the intake retain it's cast aluminum appearance once installed on the engine, or will it start to corrode?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Thu Oct 18, 2012 9:25 am
Car Model: 64 Valiant
I have seen a lot of people spray their intakes with a clear polyurethane coating to protect them from the oil grime and road dirt that always finds itself making the intake look grungy. Its slick finish keeps the dirt and stuff from getting into the pores of the aluminum making it harder to keep clean otherwise. You might try that.
PostPosted: Fri Oct 19, 2012 12:12 pm
Just curious what a dual 1bbl manifold do verse just running a 2bbl ?
Since I bought my 63 my guitar
has taken the back seat.
PostPosted: Fri Oct 19, 2012 3:53 pm
Its cooler (not talking temperature either).
PostPosted: Fri Oct 19, 2012 4:46 pm
6 Pack Dart
Better fuel distribution!
Richard
PostPosted: Fri Oct 19, 2012 6:15 pm
Its COOLER (not talking temperature, either)
There, Mcnoople......fixed it for ya. :D :wink:
Roger
PostPosted: Fri Oct 19, 2012 9:41 pm
Site Admin
It makes your linkages more complicated. :D
CJ
Users browsing this forum: halfafish and 13 guests
