It is currently Fri Jun 05, 2026 11:59 pm
 Post subject: lifters
PostPosted: Sun Oct 07, 2012 5:34 pm
any thoughts on lifters? im about to put my cam in and was wondering if there is any real difference in brands.
PostPosted: Sun Oct 07, 2012 6:10 pm
another question is why cant i reuse the lifters that are in there? ive torn down motors with a quarter million miles on them and the lifters look like there is nothing wrong with them aside from a slight indent. naturally with a motor with no where near that the indent would be much less. if that were the case why couldnt i reuse them?
PostPosted: Sun Oct 07, 2012 6:41 pm
That Indent is the wear, and its a "paired" part with the lobe that it was riding on. You will quickly and definitely wipe a new cam with old lifters. Its kind of like swapping wives/girlfriends, yeah they are both female, but with different 'patterns'. As far as your first question, not knowing what brand of cam was chosen, I would surmise any QUALITY lifter (NEW) will work.
I AM assuming also that we are talking a NEW cam? If not thats a whole other bag of worms as the original lifters NEEDS to go back to the same place they were removed from, otherwise it will also get 'wiped'....
MRO....
PostPosted: Sun Oct 07, 2012 7:04 pm
its a new comp cam. so any new lifters will work? im just asking because there are huge price differences and id like to save a couple bucks because i dont know how long im gonna run this cam.
 Post subject: Yep...
PostPosted: Sun Oct 07, 2012 7:36 pm
You can use any brand of new lifter. You can also see if there is a local cam grinding place, they might have a regrinding service for lifters to reface them for less $$$.
PostPosted: Sun Oct 07, 2012 8:01 pm
I am not for sure how tight the budget is, and why the decision was to buy cam only but Here they are
$6.24 ea. - ($74.88/set) plus shipping. I didnt go to great lengths searching and there may be cheaper places....
MRO....
PostPosted: Sun Oct 07, 2012 8:50 pm
got a deal on the cam and the budget is tight enough that im gonna be running the stock springs for a while till i get the funds to upgrade. i have enough to pick up the lifters at cost but was wondering if i could do something to save a couple bucks to get the springs too.
PostPosted: Sun Oct 07, 2012 8:53 pm
im trying to find someplace local to regrind the stock lifters but so far have had no success. does anyone know of a shop that does it in south jersey?
PostPosted: Mon Oct 08, 2012 5:20 am
buy new lifters and save the cam
PostPosted: Mon Oct 08, 2012 6:04 am
Save up your money and get the proper springs. You wil be much happier in the long run.
What number cam did you get? :D
PostPosted: Mon Oct 08, 2012 9:42 am
Car Model: 64 Valiant
There are very few companies in the entire US that can even do that, chances are they aren't near South Jersey. Just buy new ones.
PostPosted: Mon Oct 08, 2012 4:57 pm
The Egge Machine Company in Santa Fe Springs, CA, can regrind the old ones, or sell new ones for $5.46.
I also think some members have had Oregon Cam Grinding, Inc. in Vancouver, Washington, near Portland, Oregon, regrind lifters for app. $2 a piece, maybe the price is higher if you don't buy a cam at the same time.
Olaf.
Aspenized
PostPosted: Mon Oct 08, 2012 5:07 pm
i do plan on getting the right springs but for now with break in and lack of funds i didnt think the original ones would hurt for now. i got the 264s.
 Post subject: Yes but...
PostPosted: Mon Oct 08, 2012 5:24 pm
You shouldn't need a set of 340 dual springs on that cam, it would fair better with a set of 318 springs. That being said, you will need to check your springs for uniformity...I had my machinist check a set of springs from a stock motor with high miles and the springs on the head after 50K miles on a rebuild using stock slant springs with a comp 252 and at least 3 springs in each set had 10 lbs of seat pressure the rest were with in a few lbs of each other...
PostPosted: Mon Oct 08, 2012 8:35 pm
thanks for the input DI
