It is currently Mon Jun 01, 2026 1:10 pm
PostPosted: Mon Oct 08, 2012 5:42 pm
Hi, first time here. I am looking at a 1982 D150 Slant 6 with 4 sp manual toploader NP435 with granny 1st.
I want to replace with a 4 sp with over drive. What can I put in the truck?
A535 or a A833 OD?
The truck is a 4x2 shortbed.
JeffJ
 Post subject: Yep...
PostPosted: Mon Oct 08, 2012 6:46 pm
You will need to secure the linkage, tranny, bellhousing, flywheel, clutch, and drive shaft yoke from a similar year Truck to bolt in an A-833OD...( you may not need the linkage if your NP435 set up is not hydraulically actuated.
The bolt patterns between the two bells are different and the NP-435 bell houses a large flywheel with the 11" clutch...the OD tranny only used a 10" clutch and the smaller flywheel).
Unfortunately I have only mocked up an adapter plate that would allow you to just "plug and play" the A-833OD.
Sunday I just got the bell bolted to a mock block and crank and the input shaft seemed to be spot on... probably be next spring before I have it installed and working.
 Post subject: 82 D150 Granny issues...
PostPosted: Mon Oct 08, 2012 6:58 pm
The truck I found is in excellent condition, it's just the non-od 4 speed manual that bothers me.
So basically its not that simple to do (yet). I am looking for fuel economy as this will be my daily driver.
I currently drive a 1969 Plymouth Valiant 4dr 225 Slant 6 with a 904 and 14" tires. I get 16 city 20 hwy. not great, but ok.
I also have an 88 W100 4x4 319 shortbed, it sucks gas..... I don't need it want another slant 6... my 69 is my fifth slant.
Thanks for the heads up.
Jeff
JeffJ
 Post subject: ooops!
PostPosted: Mon Oct 08, 2012 6:59 pm
My bad, my 319 dodge would be very rare, it is of course a 318...
JeffJ
PostPosted: Mon Oct 08, 2012 7:40 pm
I'd be interested in the flywheel and bellhousing if there were a way to get it here at a reasonable cost.
Dave
1972 d-100 parts truck
PostPosted: Wed Oct 17, 2012 8:56 am
Do you need a floor hump as well? I know the floor hump in a granny trans truck is shaped a little differently than an 833 OD truck. Can a hole just be cut in the side of the original hump or do you need to cut the hump out and weld in an 833 hump?
PostPosted: Wed Oct 17, 2012 6:27 pm
floor hump for od trans screws to side of hump....need to cut hole and cover out top loader hole
PostPosted: Wed Oct 17, 2012 6:32 pm
Do not need the hump, I have one from a 318-np435 pickup
Dave
PostPosted: Thu Oct 25, 2012 12:02 pm
If you're getting 16/20mpg with your current dd, you probably won't get much better with a truck. I have the same setup but with a long bed and an extra 500+lbs on my truck and I can get a solid 18hwy. The best I've ever gotten was 19. And I have an hei ignition, dutra duals with a 2.5" exhaust and a homemade supersix with a Carter bbd. I still only get 16-18. If I took some weight off maybe 20mpg. With a stock.engine with an OD tranny you might be able to get better but remember, it's all in your driving habits. Also these trucks are like pushing a brick through air.
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Thu Oct 25, 2012 4:22 pm
the OD 883 is side mount shifter the nps are top load....so you need the shifter cover , and hole cut in side of hump, and top loader hole covered
Users browsing this forum: No registered users and 15 guests
