It is currently Fri Jun 05, 2026 9:31 am
 Post subject: Fisher-harmonic Dampers
PostPosted: Wed Nov 12, 2003 2:25 pm
HEY THERE GUYS LOOKING FOR ,A SFI AFTERMARKET DAMPER FOR YOUR SLANT 6 , WELL WE HAVE THEM ,FISHERCON1@AOL.COM IS THE E-MAIL IF YOU HAVE QUESTIONS OR WANT TO MAKE AN ORDER?
FOR YOUR HIGH PERFORMANCE OR STOCK ENGINES ,
WILL CHECK THIS POST ON THURSDAY .
PostPosted: Thu Nov 13, 2003 9:59 am
Tim,
Thanks for the info. Do you work at Fisher?
A lot of the Slant Six racers are using these, I have one and it works great.
Do you know if the P/N Fisher has for the Slant Six damper is the same as the Big Bolck Mopar? (383- 400-413-426-440)
 Post subject: Slant6 Harmonic Damper
PostPosted: Thu Nov 13, 2003 12:10 pm
HEY THERE DOC,
YES, I DO WORK AT FISHER'S, YES WE DO HAVE P/T#576307 THAT IS A MOPAR NUMBER FOR THE SLANT-6, BUT THAT UNIT DOES NOT HAVE PULLEYS ON IT SO YOU HAVE TO RUN A AFTERMARKET PULLEY. THAT DAMPER MAKES PULLEY ALINEMENT OFF ABOUT A 1 1/2 FORWARD.
OUR NEW PART # 374001 WILL BOLT ON WITH STOCK ALINEMENT AND HAVE PULLEY V GROOVES MACHINED IN THE HOUSING OF THE DAMPER.
COST IS RETAIL $431.00 JOBBER $325.00 BUT THERE IS ALWAYS ROOM TO PLAY
P/T 576465 ,576565 ,577506, ARE OTHER V8 MOPAR NUMBERS
PostPosted: Thu Nov 13, 2003 1:23 pm
Tim,
Are you saying that your new Slant Six damper has the pulley groove machined into it so you can use the stock belt location? I may be interested in one of those pretty soon.
Thanks,
 Post subject: New Fisher SL6 Damper
PostPosted: Thu Nov 13, 2003 1:59 pm
Tim,
Thanks for the up-date and great work up-dating the Fisher Damper so it is more user friendly.
I had to do a good amount of bracket fab. and pulley relocation work to run a "V" belt on my "old" Fisher damper SL6 but it sounds like you now have this problem solved.
Does the new grooved damper have 1 or 2 belt grooves in it?
 Post subject: Fisher/dampers
PostPosted: Thu Nov 13, 2003 6:33 pm
THANKS LOU AND DOC
YES THE GROOVES ARE MACHINED IN THEOUT SIDE HOUSING.
AND THERE ARE TWO GROOVES IFI CAN GETA PIC OF IT I WELL TRY TO PUT IT UP ON HERE
PostPosted: Thu Nov 13, 2003 8:34 pm
I'm in the market too, with two grooves will it line up for my power stearing in my 78 pickup? Bruce Johnson
78b4ramSnortbed/6
 Post subject: New Sl6 Fisher Damper
PostPosted: Fri Nov 14, 2003 12:33 pm
OK ,OUR DAMPER HAS TWO BELT GROOVES
THE ONE NEAREST THE ENGINE IS 5/8 BELT STOCK. CORRECT?
THEN THE SECOND BELT IS A 1/2 BELT THAT IS .650 FROM CENTER OF REAR PULLEY,
NOW IF THAT LINES UP WITH THE P/S PUMP , I DON'T KNOW.
THANKS FOR YOUR QUESTION
