It is currently Mon May 25, 2026 9:17 pm
 Post subject: mushy brakes
PostPosted: Sun Oct 28, 2012 9:31 pm
so finished the rear disc 8 1/4 jeep brake swap onto my Chrysler 8 1/4, bleed the brakes, and they are still mushy, and i have the brake light on, on the dash. Its weird if i pump the brakes quickly the light goes out, but the pedal is still almost hitting the floor :shock: !! I may end up getting a vacuum bleeder and suck the lines clean. I have bleed the brakes 3 times and still mushy brakes, I have triple checked all the connections for leaks and found none. Also when I have the wife pump the brakes brake fluid squirts straight up out of the rear hole in the brake fluid reservoir (rear brakes), I find that odd. thoughts comments suggestions are needed lol
-Mike
PostPosted: Mon Oct 29, 2012 4:02 am
What master cyl did you use?
Also check for excessive movement of the calipers, when stepping on the pedal. The calipers should barely move. If they move too far, it will feel like air. I just replaced a leaking MC on a 87 Reliant. Couldn't get a good pedal. Even though the front pads had good material left, the "shims" on the back were not flat, and were acting like springs, pushing the caliper back too far. This made the caliper move too much when pressing the pedal. New set of pads, good to go.
PostPosted: Mon Oct 29, 2012 5:02 am
Its the stock 2 bolt 15/16 master gonna get new pads for the rear there is about 1/8 of material left fronts still got over 1/4 left. The calipers barely move like they should.
-Mike
PostPosted: Mon Oct 29, 2012 8:25 am
Will that MC work with disc brakes on the front and rear?
PostPosted: Mon Oct 29, 2012 1:24 pm
Dunno why it wouldn't. Car came with the 10.75in rotors up front and 10in drums in the rear, if anything it should lock the rears up sooner, I don't know gonna get the vacuum bleeder and see if that helps
PostPosted: Mon Oct 29, 2012 8:46 pm
also should have mentioned the fact I had a plug in the prop valve for the rear brakes, was running only front for a bit. master seemed like the real seal was shot, almost no fluid pressure to the rear brakes, so I just replaced with a master i rebuilt, seems a little better. when bleeding the rear brakes the pedal should still hit the floor right ?? when we bleed the rear right then rear left, pedal went down just a lil bit not much, when we did the fronts it hit the floor each time.......... any ideas whats causing that, or is it normal ??
-Mike
PostPosted: Mon Oct 29, 2012 9:42 pm
I had a similar problem when I replaced the MC on my drag car.I ended up getting a 85 ish, Dodge truck MC, as my drag car has disks all around.I had to take the proportioning valve apart, and really clean it, and blow it out with air.After that, I got good peddle, before the cleaning it was like a sponge.
Just my 2 cents.
Wife's: 64 Valiant
PostPosted: Tue Oct 30, 2012 6:11 pm
may have to wait on the MC search in the boneyard, deploying tomorrow night for 17 days :roll: I will clean the prop valve, never took one apart though, so this should be intresting, btw I have never seen a prop valve like mine its all aluminium, the rest i have saw are cast iran and rusty as all hell lol
-Mike
PostPosted: Tue Oct 30, 2012 8:07 pm
I thought they were all brass? It wasnt bad to take it apart..I think I payed $35 for my MC, and it was aluminum. :D
Wife's: 64 Valiant
PostPosted: Wed Oct 31, 2012 8:03 am
Yea my bad, ment brass lol I pulled the prop valve all apart, and cleaned it, is the "shuttle valve" thingy that seperates the front and rear brakes, is that supposed to freely slide back and forth or is it supposed to be pretty snug in the bore ??
PostPosted: Wed Oct 31, 2012 9:25 pm
Not real snug, but thats what triggers the light, it gets 'off-center' and trips the light if i understand that circuit.... Havent really paid alot of attention to them as far as drag on the "shuttle" valve. (for lack of knowing proper name)
MRO....
PostPosted: Thu Nov 01, 2012 5:22 am
My 2 cents:
I don’t understand why anyone would trust a junkyard master cylinder where brakes are the top safety system in your car, and a newly manufactured unit is so inexpensive.
PostPosted: Sun Nov 18, 2012 12:16 am
For the core charge silly, if I planned on keeping it it would get rebuilt, gonna go hunting Monday and see what I can find for junk mc's, and see what's available,
-Mike
PostPosted: Sun Nov 18, 2012 4:38 am
I would suggest a new, not rebuilt, MC. It costs a few bucks more but not much if you consider it is a 50/50 chance that you will get to do it all over again with a rebuilt one. With new you don't need a core either.
Ask me how I know about rebuilt ones leaking! :lol:
Rick
PostPosted: Sun Nov 18, 2012 6:38 am
Rick
Even new is no garuntee, any more. Just recently had two bad "new" master cyls, for a 87 Reliant. They leaked out the pushrod end. Third one was OK.
I just love doing a job 3 times and getting paid once.
