It is currently Thu Jun 04, 2026 6:53 pm
Post new topic  Reply to topic  [ 1346 posts ]  Go to page Previous 147 48 49 50 5190 Next
PostPosted: Sun Nov 25, 2012 7:16 pm
Terry, I got these From Summit Racing.
oops I posted a link to the incorrect kit the other day... :(
http://www.summitracing.com/parts/wil-140-2719-bd
This is the correct Link now.
PostPosted: Mon Nov 26, 2012 6:05 am
Dang that's a lotta weight. Nice work.
PostPosted: Mon Nov 26, 2012 8:27 am
Good job Greg, are they race only? Should go and stop faster.
Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Mon Nov 26, 2012 12:08 pm
Yes these are just for drag racing Not for street or Road racing.
Wilwood has other kits similar to this one for Those purposes.
I am "weigh"ing the options of going with a rear disc Kit as well.. Currently the Kit I am looking at is about 6# of rotating mass vs the Lightest rear drumI currently have on ruster is a tad over 9#.. the other side I think is 10.25# And then The backing plates etc would get replaced with a super light brakcet / caliper / pads.
PostPosted: Mon Nov 26, 2012 7:24 pm
Well after completing the Front Disc install I figured I would start Prepping for the Roll cage install.
I laid out all the tubes, Plates and Gussets that came with the kit. It all adds up to 66.94# of roll cage (probably a Bit Less after Cutting, trimming and Notching and final fitment is complete).
So I need to Find 67 # of other Stuff to cut off the car this winter!
PostPosted: Tue Nov 27, 2012 7:08 am
Nutra system...................Yeah like I got room to talk. :lol:
PostPosted: Tue Nov 27, 2012 8:35 am
Maybe I will invite Seymour and Guzzi Mark Over while do the cage install.. I can add weight and they can chop the car, set the engine back, put an aluminum roof On, and a bunch of other gratuitous cutting and sawzalling to the front of the car!
PostPosted: Tue Nov 27, 2012 9:37 am
You can take those guys, c'mon Greg... BTW, I bet Mark's rollbar doesn't weigh more than 35#.
PostPosted: Tue Nov 27, 2012 10:18 am
You are Prolly Right Lou, But Mine is an 8 Point - It has a few more bars to the kit. Better safe with a bit more weight I guess.. and by installing it the chassis is supposed to flex less too which is a good thing.
I Might have to put windows(cutouts) in my subframe conncetors like Seymour did.
PostPosted: Tue Nov 27, 2012 11:50 am
Fair enough. Safety and stiffness are good ideas.
PostPosted: Sun Dec 16, 2012 3:40 pm
Well all of the parts of the Roll Bar Kit are Tacked in Place in the car.
The finish Welding will be done soon, I am having a Local Welding expert take a look at my practice Tig Welds Before I do any finish welding on the car.
A few Weeks ago I weighed all of the components of the rolbar Kit - It came out to 67# - after the install 9.5 # of that was trimmed or cut off the kit.
So at last Check Ruster was at 2141.7# + 57.5# for Roll bar Kit..Calculated Weight is now at 2199.2#
So I will be trying to find some areas to do some cutting - To see If I can get the car back down below 2150#
Here are Some Pics, Enjoy!
9.5# of Rollbar Kit Cut away.
These are a Few Pics of the Bars installed.. Many Times The First side I did Had a mistake that I was able to correct on the other Side.... Live and Learn..
Next Finsh Welding and Some Cutting of Junk I don't Need... Trying to Get back to 2150#
PostPosted: Sun Dec 16, 2012 5:11 pm
That looks great after you are done and it is fresh in your mind go over to my house and get the Dart. ou done all the figurn' and cuttin' so I won't have toooooo ,,,,, :P
PostPosted: Sun Dec 23, 2012 8:47 pm
My 5 point weighed 42lbs,,,I filled it with Helium :D
PostPosted: Thu Jan 17, 2013 7:55 pm
This project took quite a bit of Time in Getting all the Fab work and TIG/ GTAW done.
The Joint prep For 4130 Tubing Has to be pretty Spot on with no Gaps .. That is tedious Work.
I sure do not envy any Fab man that installs and tig welds saftey tubes into stocktype bodied cars.
It's just hard to get comfortable and get the torch and filler to work in all the goofy angles that are present in Tubing fab..
Sheesh - hats off to you guys!
Tubes are all finish welded and Painted... They actually look pretty good painted :-0
Seat and support bracket is installed as well.
Here are The pics:
On to Putting New Belts on when the Paint dries.. and Then Some Possible Lightening or Aero parts!
PostPosted: Thu Jan 17, 2013 10:58 pm
Looks EXELLENT.You should feel very proud.To me that is a pain in the ass butt when done very gratifying.Well done.Guzzi Mark
