It is currently Wed May 20, 2026 6:17 am
 Post subject: Gas cap for ethenol
PostPosted: Mon Nov 26, 2012 3:32 pm
I know it's ignorant to ask a question about a truck here but I can't find a gas cap. Seems simple. But it ain't.
I bought a new one about 2 months ago and it worked great. I could't beielve the difference.
Now, every time I go around a curve or park it with the nozzle down-hill the gas runs out. I can't get out of the truck not smelling like gas. (gas filler is right behind the door). Just like the old cap from the 60s or 70s.
I looked at the brand new gas cap and the rubber seal is all cracked.
Is is possible to get a gas cap that seals and keeps sealing? Parts store is dumbfounded.
Danny
PostPosted: Mon Nov 26, 2012 5:03 pm
Car Model: 1964 Valiant V200
short answer is no. The quality on them just sucks. My sweptline gas cap leaks too.
PostPosted: Wed Nov 28, 2012 1:23 pm
Thanks for the answer. I guess I'll try to think of something to do with it. New ones are only about $10 but I'll be buying them forever or have gas splattered down the side of the truck.
The locking cap has a weird shaped rubber. I ordered a regular one that may have just a rubber washer. I wonder if it's possible to buy gasoline proof rubber in any shape and make a washer...?
Danny
PostPosted: Wed Nov 28, 2012 4:25 pm
Make the gasket out of cork gasket material. You can buy it in sheets and cut it yourself.
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Thu Nov 29, 2012 8:20 am
I ran across this idea somewhere else with the google search but thought it might be wrong. For some reason it doesn't sink into my thick skull how cork would last longer than rubber. I think of cork and I just picture it flaking and falling apart.
Is this a tried and true idea? Is the cork anything special? Impregnated with anything? Just regular old cork? I'm sure I can find it on the internet but is this something that most autoparts stores keep in stock?
Danny
PostPosted: Thu Nov 29, 2012 8:49 am
I bought an assortment pack of gasket material at my local parts place a while back. The right sheet of cork material should work great. Cork is an organic material and as far as I know is not bothered by ethanol. I might also use a gas proof sealant to glue the cork to the cap. Something like Seal All, which has actually plugged a wet fuel leak for me as a temp fix.
http://www.epiindustrial.com/Seal-All%C ... t_Adhesive[/url]
Mattelderca
PostPosted: Thu Nov 29, 2012 9:09 am
About to go get my new gas cap and called to make sure they have cork gaskets too. I'm not even going to try the rubber one in it and go ahead and try the cork. I'll let everyone know how it works in a month or two.
Thanks for the idea,
Danny
PostPosted: Fri Nov 30, 2012 10:17 pm
The ethanol eats many things. When I was hauling fuel it would fog. crack and make our sight glasses. We had a green flat O ring for the delivery hoses. Silicone based AFAIK. I have a couple of 4" ones. Probably too big.
Users browsing this forum: Ahrefs [Bot] and 11 guests
