It is currently Thu May 28, 2026 11:35 am
 Post subject: Thanks.
PostPosted: Sun Jan 27, 2013 2:05 pm
Thats great ,Thanks .
Good Idea on getting the lash a bit tighter for less noise.
I did find a chart somewhere here,that compared many cam grinds.Ill see if I can post a link.
http://www.hal-pc.org/~bwhitejr/Slant_Six_Cams.pdf
There we go.
There is way more to cam lobe designs... then the duration & lift numbers you see.
Yes ,after reading the article I posted above, I have a better understanding .
Once again we appreciate the help.
Brendan.
PS.Ben we are on flood alert on the tweed river! water is a foot from the top of the levy bank.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Sun Jan 27, 2013 9:51 pm
Hey guys,I'm in OZ as well,have been looking at cam options locally for a very similar build have you tried Waggotts? I sent them details a while back but haven't heard back as yet,perhaps 3 customers combined would inspire them into action? I have experienced the pentastar parts cam (or at least that's what they told me was in the engine they built for my parents VC) my experience is that I wouldn't bother again,it runs decent,but nothing special and its now starting to foul #1 plug,hence Im building a replacement motor for it .Years ago I ran a heatseeker cam I bought from Watsons ,it was a very mild grind that was far superior in a mild street motor. There is also Camshaft engineering in Brisbane,I have an LPG 318 stroker they did the cam for me with good results.Failing all that,perhaps we could do a group buy from Ersons and save with combined shipping? Stay dry guys,Cheers,Steve
PostPosted: Mon Jan 28, 2013 10:05 pm
Hi Steve.
I wont be needing any camshafts soon.
I recently recieved one from Hemi Performance ,but it was the wrong one.
called them today and they are sending the correct one down as I type this,no Drama.
I have not tried waggots.wade etc. In fact I have never had to buy a cam before this one. The cam I got(am getting) from hemi Performance is supposed to be a torque type cam ,good for towing etc.
Now that doc has posted all the relative info here, I am interested to see if somebody in OZ can grind the same as the two he showed us,and for how much$??
Where did you go Ben?
Bye
Brendan.
PostPosted: Sun Feb 03, 2013 3:45 pm
So i showed the two cam designs doc posted earlier in this thread and i was advised they are hydraulic lifter cams? Is that right? If so i guess i am back to square one.
 Post subject: Whiskey Tango Hotel?
PostPosted: Sun Feb 03, 2013 4:06 pm
If your cam regrinder told you that, time to take the business elsewhere, quickly...no those are mechanical grinds.
PostPosted: Sun Feb 03, 2013 11:24 pm
Thankyou, haha that is what i thought.
PostPosted: Mon Feb 04, 2013 3:01 pm
PostPosted: Mon Feb 04, 2013 3:46 pm
"Deflection" is valve train deflection, from the lifter bores, rocker arms, valve guides, etc.
The "Hot Lash" settings tells me that these are mechanical cams.
PostPosted: Wed Feb 06, 2013 7:32 pm
Thanks again Doc, I found another supplier locally who knew it was a mechanical cam straight away. Fingers crossed for a better result. My final question is that is a cast iron cam acceptable for my application? Most aftermarket cams I have seen advertised are steel billet etc that's all.
 Post subject: Yep...
PostPosted: Wed Feb 06, 2013 9:31 pm
Iron cams were good for a trip to the moon and back in mileage terms in stock cars...never had a problem with a regrind on the stock blank or new iron blank either...billet would be good if you are going to try a roller cam profile for HP applications (not like these blanks are on the shelf...), but is not necessary for daily driving and regular dragstrip uses.
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
