It is currently Sat May 16, 2026 10:07 am
 Post subject: steel shim head gasket
PostPosted: Tue Feb 19, 2013 2:21 am
what is the likely hood that a new steel shim head gasket will work without machining the head or the block?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Tue Feb 19, 2013 2:28 am
Off the top of my head I'm going to say....
zero
PostPosted: Tue Feb 19, 2013 3:27 am
Check the deck, and the head with a straight edge. My cuda has a shim gasket without cutting the deck, but does have a milled head.
My 66 Valiant was originally built with the shim gasket and no cut on the head or block. Ran a couple of seasons, before we cut the head, for a compression increase. Still using the shim gasket.
PostPosted: Tue Feb 19, 2013 11:06 am
Could work... IF you have a "long board" sanding block and a lot of "elbow grease".
You will have to pull the dowel pins out of the block deck and start sanding... and checking, with a straight edge, before you know for sure... If the head or block is un-even or warped, it is best to spend the $$ to get them resurfaced.
It is always interesting to see the "high - low" areas when you start sanding... the block in my photos below had "zebra stripes". :shock: :?
PostPosted: Tue Feb 19, 2013 1:41 pm
thanks for the replys guys.
doc, is that "board" wood or a piece of steel?
PostPosted: Tue Feb 19, 2013 1:48 pm
I use 16 ply Finish Birch plywood. It works very well.
PostPosted: Tue Feb 19, 2013 3:23 pm
what grit sand paper?
also my block isnt disassembled is there a way to keep the metal shavings out of the passages?
PostPosted: Wed Feb 20, 2013 5:24 am
also my block isnt disassembled is there a way to keep the metal shavings out of the passages? NO
PostPosted: Wed Feb 20, 2013 7:36 pm
80 grit belt from a vertical belt sander belt. Use a little WD 40.
PostPosted: Thu Feb 21, 2013 12:23 am
cool, thanks man
Users browsing this forum: Google [Bot] and 14 guests
