It is currently Thu Nov 12, 2026 4:15 pm
PostPosted: Mon Feb 18, 2013 8:38 am
Poser
First off thanks to Rick Covalt for loaning me his alum adapter plate made up by Team Green. A local machinist buddy of mine has spent the time and energy to develop a print and program to reproduce these. This is based on a Lakewood bell.
DadTruck will be using this as a first step to adapt his smblk Quicktime bell. The goal of this adapter is to: #1 protect your feet and #2 run V-8 clutch,pp, and flywheel.
This is a project that is ongoing and I will keep all of you updated. If you had ever considered running a stick - things may have just gotten a little easier.
PostPosted: Mon Feb 18, 2013 4:02 pm
Very cool!
PostPosted: Mon Feb 18, 2013 6:27 pm
YAY
Sound like a fun project.
 Post subject: Like This?
PostPosted: Mon Feb 18, 2013 6:57 pm
PostPosted: Mon Feb 18, 2013 8:52 pm
thats sexy right there lol,
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Mon Feb 18, 2013 11:14 pm
Is that the long rumored "portless" slant six? and the equally shy crossflow, with the exhaust on the right??
Nice lookin' bellhousing, too!
ATB
BC
PostPosted: Tue Feb 19, 2013 3:12 am
Poser
Nicely done Hyper_Pak! Looks like ya put the starter back where it belongs.
 Post subject: Blowproof
PostPosted: Tue Feb 19, 2013 7:06 pm
Thanks for the comments. But no it's not the portless crossflow head.
And yes the starter is where it is supposed to be, but it didn't work. Broke a bunch of starter noses. I went with a Tilton starter with no nose and never had another problem.
I would not use a small block bellhousing again though. Too many bolts overlap and it just was the hard way to do it. Nexy project will be the big Lakewood 2 peice Big Block unit. Should easier to adapt and make work. But I don't have a small tunnel to work with either. No nose starter is one key. McLeod made my flywheel, stock 340 32 lbs with a early slant six flange pattern.
 Post subject: Phase II
PostPosted: Sun Feb 24, 2013 3:48 pm
Starting to mock up the modification. Here is the Lakewood on my AL slant.
PostPosted: Sun Feb 24, 2013 6:23 pm
popcorn
PostPosted: Sun Feb 24, 2013 7:35 pm
i hope you have a lot.................I am Slooooooooooooow.
 Post subject: Re: Blowproof
PostPosted: Sun Feb 24, 2013 9:02 pm
Car Model: 64 Valiant
So the SBM bellhousing isn't the best choice. Isn't the BBM bellhousing a lot larger. Any problems trying to get it to fit into some A bodies as far as tunnel clearance.
PostPosted: Mon Feb 25, 2013 6:10 am
What about SB Ford or Chev?
 Post subject: Ford or Chevy?
PostPosted: Mon Feb 25, 2013 5:49 pm
My mom would wash my mouth out with soap when I would say words like that LOU!
The problem as I see it from my myopic point of view is any bellhousing that is around the slant six mounting flange will have to have countersunk fasteners. By going with this bigger unit I can use regular bolts with a normal clearance around the bolt diameters. The two peice can be opened from the bottom to service the clutch.
As for space, 67 Up should be no problem, they put BB's and Hemi's into those bodies. 66 back will require some fixing.
On my Colt I will have all the room I need.
PostPosted: Tue Feb 26, 2013 12:11 am
Ok, from that pic its obviously a Hemi with a tunnel ram, with a Lenco in a 90 something inch wheelbase car........scary!
