It is currently Wed May 27, 2026 8:31 pm
 Post subject: speedo cable
PostPosted: Wed Feb 20, 2013 3:59 pm
can anyone tell me the correct part number for the speedometer cable for a 1964 valiant automatic. I ordered 1 from Rock auto and of course it is not the correct 1 . the 1 I need screws on at the speedometer but pushes in at the transmission . Just replacing the inner cable will not work as mine is totally mangled thanks
If only I had the time to do what I want to do instead of what I have to do!
PostPosted: Wed Feb 20, 2013 7:13 pm
'64 parts manual shows the cable as part #21-84-1.
I found one N.O.S. on ebay, HERE.
Or, Schumacher Creative Services has new ones here, scroll down about 2/3rds of the page.
ATB
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
 Post subject: apwwdp
PostPosted: Thu Feb 21, 2013 6:06 am
Thank you very much
PostPosted: Thu Feb 21, 2013 1:03 pm
Glad I could help!
ATB
BC
PostPosted: Thu Feb 21, 2013 1:25 pm
http://www.imperialservices.net/Aparts.html
Imperial has them also.
1964 Dart GT
 Post subject: Speedo
PostPosted: Tue Feb 26, 2013 6:04 am
I would guess they instruct you on what kind of lubricant to use but if not, what did you guys use..thanks
PostPosted: Fri Mar 01, 2013 8:44 pm
Use a good quality silicone grease all up and down the inner cable, and then wipe it off the top 6 inches or so. That grease can migrate into your speedo and kill it.
ATB
BC
 Post subject: cable
PostPosted: Fri Mar 01, 2013 9:45 pm
Thanks again! :)
PostPosted: Sat Mar 02, 2013 4:44 pm
With that done, your speedo cable should serve well for another 40 - 50 years. I don't know about you, but in four decades I'm pretty sure I'll be pushin' up daises and won't care if the speedo works :lol: :lol: :lol:
ATB
BC
PostPosted: Sat Mar 02, 2013 5:02 pm
Considering Im over ten years older than the car I would concur :lol:
