It is currently Sat Oct 10, 2026 3:59 pm
 Post subject: carter bbs # location
PostPosted: Sun Mar 03, 2013 11:11 am
I would like to get the correct kit for my 64 and down bbs. Its got several numbers on the top, body, and base. The top has a 6-1543 and the body and base have different numbers but similar layout.
I found a old "carter" kit but unsure if that's of good quality and if its even right for mine
PostPosted: Sun Mar 03, 2013 11:29 pm
Nothing? I'd lke to order monday
PostPosted: Mon Mar 04, 2013 12:56 am
I used this page .
ATB
BC
PostPosted: Mon Mar 04, 2013 6:59 am
No tag on a bowl screw? You just have to guess. Most carb kits have gaskets that cover multiple years. Save your old gaskets to match with the new ones.
That's the way of the BBD and BBS world.
PostPosted: Mon Mar 04, 2013 8:13 am
I have no tag went on that daytona parts and it first comes up with 1 kit # from 60-71. I click that number. Then it shows 2 parts kits. It also says I can identify length of plunger rod to determine what kit to use. Can someone tell me length and carb number? Or has no one ever recorded that kind of info
PostPosted: Mon Mar 04, 2013 11:05 am
Can't vouch for accuracy, but HERE'S a list of numbers.
PostPosted: Mon Mar 04, 2013 2:24 pm
Thanks! What would be the difference high performace vs the standard
PostPosted: Mon Mar 04, 2013 4:35 pm
Ordered mine from napa, worked great and included parts for several different models.
74 Dart Swinger, supersixed.
PostPosted: Mon Mar 04, 2013 4:41 pm
I've been told I need to oil and flare the new plunger? What exactly do I need to do. I believe to have found a kit, and get carb back from rebushing tomorrow wouls like to get everything done and driving for tomorrow.I've read the manual a few times and never saw about oiling and flaring. .
PostPosted: Mon Mar 04, 2013 4:52 pm
Direct answer to your question: Very darn little. My guess is that the Chrysler engineers had some certain specifications for the service a given carb was intended for, so they had Carter (& their other vendors too, I expect) build 'em to those specs. Maybe jet changes, linkage settings, length of accelerator pump shaft, others??
From the Carburetor Shop listings, I count nine different carb numbers. They use three different kits (apparently Carburetor Shop's own numbers)
When I click on the Daytona # 421, I get a msg that the picture is coming soon. The picture that IS shown does mention identifying the carb by the accelerator pump stem length, but doesn't tell what length for which carb - or which kit, thus your dilemma.
IMNSHO, you are overthinking this issue, just like I did several months ago. When the info stream ends all I could do was say "W.T.F.???"
Here are my notes from many hours on the net and the phone. They might help, or they may confuse you. Nonetheless, the fruits of my labors:
The Carburetor Shop (573) 392-7378 (9-4 Mon-Wed central time) John ("Crazy John" in Missouri", according to Ron at Daytona)
Parts are available individually, a repair kit for the carburetor is the minimum order.
Kit # 2128 Carter carb #3838 (superseded by #4198) (kit:$72.00
He has a nos 4198 - $600.00 (Wonder if it would need kit?)
Walker Products 1-970-245-5949
Carb Kit: #: 15483A Kit Instruction: 50-735.pdf
Daytona Parts Co. (386)427-7108 (Ron)
$250 + parts & shipping to rebuild your BBS.
Ron @ Daytona mentioned:
All-American carbs Jacksonville fla (904) 215-6790 REMANUFACTURES carbs (I didn't call them)
I ran all eight of the numbers through the OEM lookup on the Walker page (one # is duplicated) they ALL came back with the same Walker kit # - 15483A.
I got mine at O'Reilly's auto parts, but I'm sure most of the generic parts stores can get that kit.
My nearby O'Reilly's had one on the shelf.
Oiling and flaring: Soak the leather plunger end in light oil for several hours, then spread it out so that you have to guide it into the pump well.
ATB
BC
PostPosted: Mon Mar 04, 2013 4:59 pm
Cool thanks!. I'm still wondering about the whole oiling and flaring thing
PostPosted: Mon Mar 04, 2013 5:57 pm
I think they want you to soak the plunger in oil to swell the seal, than take like a small screwdriver under the seal and gently run it around it pulling it outward so it seals good in the well it sits in
PostPosted: Mon Mar 04, 2013 6:11 pm
ohh okay thanks, any kind of oil works?
PostPosted: Tue Mar 05, 2013 8:50 am
What brand did they sell you?
Did you get a leather or rubber accelerator pump? I was wondering about using brake fluid. Or would that be corrosive?
PostPosted: Tue Mar 05, 2013 3:12 pm
Car Model: 1966 DodgeDart
I would use Daytona. They have a COMPLETE Kit -including idle mixture screws. Mine were mis matched and they came thru for me. Saved me running to order other partsIneeded to complete the job.
1966 Dodge Dart 225
2005 Dodge Dakota 225
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 17 guests
