It is currently Mon Nov 09, 2026 1:45 am
 Post subject: 904 racing mods
PostPosted: Mon Mar 18, 2013 7:44 am
anybody have a link or information on the mods to the internals of a 904 for improved racing performance?
PostPosted: Mon Mar 18, 2013 8:25 am
Here are some things I did:
http://slantsix.org/forum/viewtopic.php ... c&start=15
http://slantsix.org/forum/viewtopic.php ... c&start=30.
Dont do the Griner Vent Relocate - It did not work for me.
Unfortunatley the A&A trans Website seems to be down :-(
http://www.aandatrans.com/departments/c ... trans.aspx
I have a catalog of their stuff and most of it is on my wish list.
I think the stock 904 behind a slant is okay for the most part.
Install new bushings, Bearings seals etc. on all the pistons/Drums Etc. Block the accumlator - You can make one from some AL tube from the Hardware store.
Get quality clutches and steels / Bands - Alto Red Clutches are in ruster's 904 with no problems yet.
Call up A&A to discuss what you are trying to do.. they will help.
I also Have A transgo TF-3 Full valvebody in the 904 - if you go with a full manual V/B then you can get rid of the govenor and Heavy Park Gear and get the Aluminum Parts from A&A to replace ma Mopar's heavy Cast Iron Stuff.
 Post subject: Start Here.
PostPosted: Sat Mar 30, 2013 9:47 pm
http://www.allpar.com/mopar/transmissio ... -hand.html
Some mods off the top of my head.
High performance clutches and steels.
Extra clutch and steel in 2/3 pack
904 v8 band for 2/3 /or special kevlar piece
higher ratio band lever
Valve body mods/Shift Kits vary depending on performance level
4 pinion planetary gears
Billet aluminium Drums and spinning bits.
Block off accumulator for firmer upshift
Perhaps bolt in sprag mod( not sure in 904, Done in 727)
hi Po converter
there is more but thats all I can remember at the moment.
Check through these forums. Read Read Read. make a list then decide which you need to do.
Check out this mob.
http://smrtrans.tripod.com/smrtransmiss ... index.html
this article
http://www.moparmusclemagazine.com/tech ... ewall.html
Brendan.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Sun Mar 31, 2013 2:34 pm
I have a full manual body, the front drum is drilled to lube the kick down band and allow fluid out faster from the clutches. I didn`t drill the fluid passage in the pump assembly between the two sealing ring, also the faster ratio leveler, I have the 5.0 to go in. there are a few mods in these articials I can try. thanks
