It is currently Wed May 27, 2026 4:14 am
 Post subject: Degreeing stock cam
PostPosted: Mon Mar 18, 2013 3:12 am
I am going to go help one of our newer members here to degree in his stock cam in a daily driver. The intake centerline is 106. Should I advance a stock cam for him to get the best performance he can? 4 degrees? I believe this is a bone stock engine.
Rick
PostPosted: Mon Mar 18, 2013 10:27 am
It would help bottom end
PostPosted: Mon Mar 18, 2013 1:09 pm
For a stock cam, I would run it at 101-104. Try to get the '71-up higher lift version.
PostPosted: Mon Mar 18, 2013 3:51 pm
Cam was already in the car, and it was at 110 degrees, plus the timing Mark was off by 3 or 4 more degrees. So I got his damper marked correctly and adjusted it to 102 degrees.
thanks.
Rick
PostPosted: Mon Mar 18, 2013 5:16 pm
thank you very much Rick im going to put it back together tomorrow and see how she runs after a valve lash adjustment :D
trying to keep it low key here in my Valiant200
PostPosted: Fri Apr 05, 2013 7:20 pm
got everything tuned in and the timing is set at 10 degrees with the valve lash set at .012 intake .024 exhaust and i converted to electronic ignition so i dont have to deal with the pesky points burning up
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
