It is currently Thu Jun 11, 2026 10:22 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Wed Mar 20, 2013 8:11 pm
Anyone have the link to SSD's ground strap recommendation?
Do a search on NIPONDENSO alternator conversion...
In short....
Run a strap from the alternator ground stud, to the voltage regulator bolt. Be sure to scarp off the paint so it makes a good connection. That should settle it down unless your battery is old and going.....mud in the bottom shorting the bottom of the plates.
PostPosted: Mon Apr 01, 2013 6:07 pm
I did everything that you guys had listed. I am not at 14.5 volts. Makes me happy. I thought I would never get mine lowered.
 Post subject: Grounding
PostPosted: Mon Apr 01, 2013 9:11 pm
I cant tell people enough that grounding is a must :!: . It doesnt matter what I drive, I make sure that there are grounds (of good size) from battery to frame to engine to body. And I always try to link them with the same studs if possible. When i got the slant it had a typical 8ish guage ground from battery to inner fender, 10ish to the back of the water pump and a 14! :shock: to the radiator support. Local audio store for 6 gauge wire, lowes for the ends and 45 min later I had no issues with grounds 8) . Works well for presetup to do the HEI swap too :twisted: . Worst part was, I was at Ft Lee about 6 mo into an electronics course, so electrical was the last thing I wanted to mess with. :roll:
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Tue Apr 02, 2013 6:11 pm
Is there any thing I can do it stop it from vibrating so much?
You should find the source for the vibrations, such things have a tendency to damage parts over time. Are the pulleys not in line, or maybe damaged?
Olaf
Aspenized
PostPosted: Wed Apr 10, 2013 6:40 pm
Just went out and installed the grounding wires from my alt casing and VR to my negative terminal and all the surging is gone.
Thanks you guys!
Aspen76
76 Dodge Aspen
225 Super Six w/ Dutra True Dual Exhaust
http://i1245.photobucket.com/albums/gg5 ... AG0095.jpg
http://www.youtube.com/user/BZuko1?feature=guide
