It is currently Mon Jun 15, 2026 4:54 am
Post new topic  Reply to topic  [ 220 posts ]  Go to page Previous 110 11 12 13 14 15 Next
PostPosted: Wed Mar 20, 2013 6:29 pm
I'm a little confused by the findings here, I'm sure you are as well ! Now,resistance between coil pos and neg terminals is indicating open circuit? If so coil is toast,use your old canister for troubleshooting.
The b term on HEI module should have power,full steady power,12v
The pos term on coil should be the same as above,full power
The neg coil term goes to the "c" term on the HEI module ( forgive me if that's not the correct letter,but its the other terminal on the module next to the pos terminal
Now ,remove the wire coil neg,attach one wire of test globe to it and the other wire of test globe to the wire you just removed...ie wire the globe in series.
Crank engine,light should flash
If no flash then you probably have an issue with you trigger,did you check your reluctor gap and the wiring connectors? Did you fix up that earth screw on the module? It needs a good contact as I've mentioned before for heat transfer,electronic noise and to be able to earth the circuit form the coil neg wire.
Did I read you are running msd 5 ohm wires? I'm not familiar with them,but they should be suppression wires, 5 ohms sounds like solid core wires.
Dan did a fine job putting together info on this site,but its not " dans conversion" it's been done to thousands of different cars around the world so don't feel your sailing uncharted waters here
I'm personally running pertronix module and .6 ohm canister coil with magnecor suppression wires and zfr5n,with a tired battery it still starts fine,the limiting factor is being able to crank it over,not getting spark.
Hang in there.....you'll win!
PostPosted: Wed Mar 20, 2013 6:49 pm
Car Model: 1967 Dodge P200 Post Office Vehicle
Stop!!!!!!!!! do not worry about whether the coil is bad or not. Coil good or bad does not make any difference, at his point. The module is not sending a trigger to the coil.
Hey Charrlie,
Alright.
Do one step at a time. Get a trigger, first.
Alright.
The lite dimming slightly while cranking is normal, due to the changing load the starter puts on the electrical system.
Kind of suspected that THAT was the case.
Even if the distributor pick up is within Ohms spec, it can still have a problem. Two things to do. Remove the distributor, connect a low volt meter to the pickup leads, and spin the distributor. See if you get a reading.
All I have is a Radio Shack Multi-Tester. Will THAT do?
Also check the gap between the teeth on the reluctor, and the metal pole piece of the pickup coil. It should be .008 with a brass feeler gauge.
Alas, do not have a Brass Feeler Gauge.
If the gap is too wide it will not generate a signal.
Am going to have to find something non-magnetic that is .008 thick.
Either before or after checking the distributor, take the module to the part store and have it checked.
Alright.
PS: the HEI module should still work, even if the voltage supplied by the battery is as low as about 8 or 9 volts.
Don't know what the "cranking" Voltage is, but the Battery is a brand NEW NAPA Legend 75, and should be plenty strong.
Once you get trigger to the coil, then worry about whether the coil is good or bad.
Alright.
PPS: Make sure the module has a good ground. Not a (-) terminal connection, but a good ground to the back, and screw hole of the module.
The NAPA Echlin TP45 Control Module has a Dedicated Ground Strap going from the Front of the Module Mounting Screw to a Valve Cover Hold-Down Bolt.
Thanks for the VERY informative response.
JC
Lorrie Van Haul - 1967 Dodge - P200 Post Office Vehicle - 225 Slant Six - Torqueflite A727 Automatic Transmission - Right Hand Drive Steering - Big Three HEI System - Frantz Oil Cleaner System - Bendix Stromberg Model W Carburetor
PostPosted: Wed Mar 20, 2013 7:04 pm
Find a thick business card. Some are made of plastic which are about that thick.
Not my first choice or a good enough ground. Pick a chassis ground or go to the battery to be sure.....
PostPosted: Wed Mar 20, 2013 7:15 pm
Bad wiring, bad connections can lower voltage, doesn't depend on new battery.
Hey Mr. E,
The wiring is all NEW, the Connectors are clean and tight.
My thinking is as follows (sorry didn't think of this till now)
When cold, a battery doesn't produce as much volts, and with either bad wires or connections, the voltage may drop below a threshold that produces a spark. (plus a cold engine has more cranking resistance)
The Battery is a NAPA Legend 75, almost 13 Volts, Cranking Amps: 1075 @ 32 degrees F, Cold Cranking Amps: 835 @ 0 degreed F.
Pulling the wire and checking for a spark might not be enough of a test. It takes less energy to jump to ground than to jump the spark plug gap because of the cylinder compression.
The check for spark was done with the Spark Plug in the Spark Plug Wire Boot and laid against a ground. The only thing that would be different would be the compression, which in Lorrie is not all that high.
So it may look like you have sparks, when you really don't.
Alright.
What I remembered was when my motorcycle battery was getting old. The bike would crank, but not start. Then it would just catch and run right after I released the starter. Evidently the voltage went up because the starter was off, and then I had a spark for that last bit of cranking.
I found that I was below 9 volts at the ignition module due to the convoluted wiring (and small gauge wire used) when cranking.
I fixed the problem by rewiring to the ignition module with a relay so that the ignition module had as many volts as possible.
All the Wires in Lorrie's Electrical System are 12 and 10 gauge.
Have seen that page. Strangely, the Adobe Acrobat Reader garbles the text to where it is unreadable! Wouldn't you know?
If you can temporarily supply the ignition module and coil with it's own power supply, you can see if voltage drop is your problem.
Might run a direct wire from the Battery's "+" Post to the "B" Terminal of the NAPA Echlin TP45 Control Module.
Or you can do what I did with my old Mazda RX2........ I used some starter relays and an extra battery so that when starting there was 24volts supplied to the starter.......
Think I will pass on THAT. :) Am not wanting to hurt the Starter. The NAPA Legend 75 Battery is plenty powerful.
Will be doing everything step-by-step as Charrlie suggested.
I just got out my Feeler Gauges, and took a look at the 0.008 Blade. IIRC, when looking at the Reluctor Tooth in relation to the Pickup Tooth in the Distributor, it looked somewhat wider than what the 0.008 Feeler Gauge looks to be. Will check THAT tomorrow.
Anyway, hope we are going to get this solved. If nothing else, this has been a GREAT education.
Hope you are well.
JC
PostPosted: Thu Mar 21, 2013 4:59 am
I'm a little confused by the findings here, I'm sure you are as well!
Hey Steve,
Am almost past confusion, heading for anarchy! :)
NO. We're getting a reading of .7 Ohms between the "+" and "-" Terminals of the Ignition Coil, but a reading of Infinity between the "+" and the Output Tower, and a reading of Infinity between the "-" Output Tower of the Ignition Coil.
Also, we're getting a light with the Test Light between the Ground and the "+" of the Ignition Coil, and between the Ground and the "-" of the Ignition Coil.
AND we're getting no "blinking" of the Test Light when the Engine is cranked. Charrlie says that the FIRST THING that is needed is to get THAT trigger signal from the Distributor, which tests at 277 Ohms.
If so coil is toast, use your old canister for troubleshooting.
Have found that NAPA in Livingston has a replacement for the Standard Blue Streak FD478X for less than $40.00 and am going to get that, hopefully today to have on hand for troubleshooting, as to use the old canister Ignition Coil would entail having to rewire.
The b term on HEI module should have power, full steady power, 12v.
It HAS full and steady 12.XX Volts depending on the Battery charge!
The pos term on coil should be the same as above, full power.
It too HAS full and steady 12.XX Volts depending on the Battery charge!
The neg coil term goes to the "c" term on the HEI module (forgive me if that's not the correct letter), but its the other terminal on the module next to the pos terminal.
"C" IS te correct letter. And THAT is where the "-" Wire FROM the Ignition Coil is connected to the Control Module.
Now, remove the wire coil neg, attach one wire of test globe to it and the other wire of test globe to the wire you just removed. ie wire the globe in series. Crank engine, light should flash.
Do you mean to DISCONNECT the "-" FROM the Ignition Coil from the Control Module and test between it and the "C" Terminal of the Control Module for "flashing" (blinking) when the Engine is cranking?
Have NOT been DISCONNECTING the "-" Wire from the "C" Terminal to see if it would blink. Will try THAT at first light this morning.
That's what Charrlie has suggested.
Did you check your reluctor gap
NO. But plan on doing THAT today.
The Wiring and Connectors are both NEW and CLEAN, and am getting a reading 277 Ohm when testing between the TWO Wire connected to the Distributor.
YES. It is solid, well connected and grounded to the Engine Block via a Valve Cover Hold Down Bolt.
It needs a good contact as I've mentioned before for heat transfer, electronic noise and to be able to earth the circuit form the coil neg wire.
It is in place and functioning.
YES. They are MSD 8.5mm Wires with 5 Ohm of resistance per foot of length. $100.00 a set. Am running them on the 1964 Galaxie and they are Fine.
I'm not familiar with them, but they should be suppression wires, 5 ohms sounds like solid core wires.
They ARE solid Copper Alloy Core wires.
Dan did a fine job putting together info on this site, but its not "Dan's Conversion". It's been done to thousands of different cars around the world so don't feel your sailing uncharted waters here."
Well, doing this kind of thing is "uncharted waters" for ME.
I'm personally running pertronix module and .6 ohm canister coil with magnecor suppression wires and zfr5n, with a tired battery it still starts fine, the limiting factor is being able to crank it over, not getting spark.
Am getting .7 Ohms between the "+" and the "-" of the FD478X Ignition Coil, BUT a reading of Infinity between the either the "+" or the "-" Terminals of the Ignition Coil and its output Tower.
[/quote]Hang in there.....you'll win![/quote]
This has turned into an ordeal of dogged perseverance!!!
Anyway, it's onward through the fog.
JC
PostPosted: Thu Mar 21, 2013 5:58 am
Hey Ted,
Am hopefully going to be going to Livingston today and will get a set of Brass Feeler Gauges.
Alright. Will give THAT a try.
JC
PostPosted: Thu Mar 21, 2013 8:46 am
Hey All,
Thursday Morning Update:
Have been to Livingston in Dale, the Welder's Truck. Got a NEW NAPA Echlin IC24 Ignition Coil. It LOOKS like the FD478X, except it is Black. Am hoping that the Connector will fit.
Also got a set of Brass Feeler Gauges.
So it has been a VERY active (at least for me) morning, and am going to have to take a break. Maybe have something to eat, and then will be un-installing the HEI System Assembly, changing out the Ignition Coils. Then removing the Distributor Cap and seeing what the Reluctor Gap is set at.
Am going to, if it is more than 0.008, readjust it.
Is there anything that has to be watched-out for.
Have done some research on the subject of Reluctor Gap Adjustment and one of the things is to make sure that all the Reluctor Teeth are not hitting the Pickup Tooth. And that includes when the Centrifugal and Vacuum Advance Assemblies are working.
Is there a way to know THAT?
Any heads-ups as far as Reluctor Gap Adjustment would be GREATLY appreciated.
Will, of course, keep the updates coming.
JC
PostPosted: Thu Mar 21, 2013 12:07 pm
Well Guys,
Am sitting here with both the OLD Standard Blue Streak FD478X Ignition Coil AND the NEW NAPA Echlin IC24 Ignition Coil sitting on the bench.
Have tested each of them for resistance.
The FD478X has 8.51 K Ohms between both the "+" and "-" Terrninals and the Center Post.
The IC24 has 7.81 K Ohms between both the "+" and "-" Terminals and the Center Post.
And both have .6 Ohms between the "+" and "-" Terminals.
There doesn't appear to be anything wrong with either of them.
Tested the Distributor for voltage by hooking the MultiMeter Probes to the two Wires coming from the Distributor, and cranked the Engine to make the Distributor turn.
All the Multi-Meter did was flash a bunch of numbers on the Digital Read-Out, but I couldn't read them, they happened so fast.
Anyway, am going to reassemble the HEI System Assembly with the NEW NAPA IC24 Ignition Coil installed.
And before the Assembly gets reinstalled, am going to check the Reluctor Gap.
Will let you know what is found.
JC
PostPosted: Thu Mar 21, 2013 12:47 pm
Hey All,
Thursday Afternoon Update:
May have found the gremlin.
Checked the Reluctor Gap.
It is 0.014!
Tried to move the Distributor Shaft nearer and further from the Pickup Tooth, and it wouldn't move more than 0.001.
Am going to adjust the Reluctor Tooth to Pickup Tooth Gap to 0.008.
Will let you know how THAT goes when finished.
JC
PostPosted: Thu Mar 21, 2013 1:15 pm
Getting closer!
PostPosted: Thu Mar 21, 2013 1:55 pm
Hey All,
Got the HEI System Assembly reinstalled.
Adjusted the Reluctor Tooth to Pickup Tooth to EXACTLY 0.008".
Lorrie is all back together.
Just as I was finishing, the wind started to blow REALLY hard, and it started to rain. So I cleaned up the Tools&Materials and beat a hasty retreat back to the confines of the Sound/Music Studio where the Computer is.
Am going to go out tomorrow morning, run all the usual test to see if everything is getting electricity where it should be and make sure that there is no electricity where it shouldn't be.
Then will see if Lorrie will Start&Run.
Will let you all know what happens then.
JC
PostPosted: Thu Mar 21, 2013 2:01 pm
Getting closer!
Hey Reed,
Am feeling like the old Turtle that was trying to cross the finish line, but it could only go half way to the line each day. There was always half the distance to the finish line left to go. The poor old turtle never did cross the finish line.
Anyway, we will see in the morning if what was done today will induce Lorrie to finally Start&Run.
Will just have to wait and see.
Time will tell.
Be well,
JC
PostPosted: Thu Mar 21, 2013 2:45 pm
.014" is pretty big, over 1.5 times the recommended tolerance....mopar quality control can be less than ideal, mind you, I don't think I'd like the job of setting reluctor gaps all day ! It's great you found something, that gap wouldn't help your starting at all. The rambling numbers on the multimeter is good enough for me to feel the pickup is working and producing a signal, maybe just not a strong one with the large gap. On another subject... Coil and plug wires, I would run suppression type wires if it was me, those solid cables are race only and put out lots of noise, you now have electronics on board lorrie, ie vr and hei, will the noise cause a problem I don't really know for sure, but if you reluctor wires go anywhere near those msd cables I'd be worried about false signals.... Just my thoughts here, maybe someone has more experience here, but for a few bucks for a decent set of suppression cables it may be good insurance.
PostPosted: Thu Mar 21, 2013 3:48 pm
Getting closer!
Hey Reed,
Time will tell.
Be well,
JC
I will have to start calling you Sisyphus! Not that I think you are deceitful, though.
PostPosted: Thu Mar 21, 2013 5:22 pm
Hey Steve,
Another .002 and it would have been double the specified gap.
mopar quality control can be less than ideal, mind you, I don't think I'd like the job of setting reluctor gaps all day!
Have to agree. Once upon a time was working for Larson Boats on an assembly line. Lasted a month.
Hopefully the Gap was the problem all along.
Well, one of the guys over at FordMuscle noted that the MultiMeter should have been set to read Alternating Current.
Just went and got the package in which the MSD Cable came. Let me quote what it says on the box:
"HIGH EMI SUPPRESSION
Electro Magnetic Interference (EMI) is a magnetic field that radiates from all spark plug wires. This field will interfere with on-board electronics, ignitions, rev limiters and can even be heard in your speakers. Even with its low resistance, the 8.5mm SC wire has outstanding EMI suppression capabilities. The copper alloy conductor is tightly wound in a special fully stacked manner around a ferro-magnetic impregnated center core. In fact for every foot of plug wire, there is over 40 feet of conductor windings! This winding procedure combined with the special material creates a highly effective EMI choke."
you now have electronics on board lorrie, ie vr and hei, will the noise cause a problem I don't really know for sure, but if your reluctor wires go anywhere near those msd cables I'd be worried about false signals.
The Wires from the Distributor are about 4" below the "drool tubes". The Electronic Voltage Regulator is about 20" away, from the Spark Plug Wires. When Lorrie was running, there wasn't any kind of problems.
Let's see how these MSD Wires work out. If anything shows up, will have to do what you suggest.
Thanks for the heads up though.
JC
