It is currently Thu May 28, 2026 11:38 am
PostPosted: Fri Mar 29, 2013 1:57 pm
I got to my car this morning to find some someone had tried to steal my car. I found a 20 lb dumbbell sitting on my passenger seat, a broken pocket knife, a broken screw driver, my inside mirror smashed, pieces of my ignition switch on the floor and my shift lever snapped off!
I guess I'm lucky the idiot was unsuccessful but was still left with some damage to the car, making it undrivable. The ignition lock cylinder needs to be replaced, that I already bought but I cannot figure out how to remove the old one. I got a steering wheel puller but with out being the electrical portion of my factory manual, I'm thoroughly confused.
If anyone could take a look at the pictures below and give me some instruction how to remove it, I would very grateful. I need to get the car out of the place it's parked now.
I think I need to remove the screw in top right, and stick a small screw driver down that hole but I can't grip the cylinder in anyway to pull it out.
1978 4 door Dodge Aspen, Super Six
PostPosted: Fri Mar 29, 2013 5:39 pm
I think you need to remove the turn signal switch & top housing on steering column, then there should be a screw that holds ign. cyl. in place than you can use a screw driver to pry it out from the inside
PostPosted: Fri Mar 29, 2013 6:20 pm
If you have the 1978 chasis-body service manual. Look at section 19 page 30 . Ignition key,lock and switch removal covered there. Not in electrical section.
PostPosted: Sun Mar 31, 2013 1:49 am
Thanks, that is perfect. Should have it good to go by Monday.
PostPosted: Sun Mar 31, 2013 8:13 am
If stuff is broken, and you need a column, let me know.I have a column out a 71 dart with a key, and a shifter....sell it cheap.No idea of the shipping though.
Wife's: 64 Valiant
