It is currently Thu Jun 18, 2026 5:07 am
PostPosted: Fri Mar 29, 2013 4:18 pm
I have ditched the original lean burn system on my '82 W-150 and have bought a kit with a 5-pin regulator. The system uses a double ballast resistor. Problem is, there are obscure references in the installation instructions on how to wire the alternator that seem to contradict themselves. The alternator has two field connectors. I checked Paul Moran's wiring guide, but he leaves out the alternator connections. Any suggestions gratefully accepted.
Dave[/img]
 Post subject: This one...
PostPosted: Fri Mar 29, 2013 4:44 pm
http://www.allpar.com/history/mopar/electrical.html
I'd use the diagram at the bottom of the article marked electronic that shows everything that hooks up in EVR circuit in 1973+ vehicles. Ignition modules are 4 or 5 pin, the EVR is 2 pin-triangular if stock 1970+ mopar.
 Post subject: Whoa!
PostPosted: Fri Mar 29, 2013 8:50 pm
Lemme see if I have this right. Do you mean my 5-pin ignition module, with the big fat transistor on it, does not do voltage regulation?
Dave
PostPosted: Fri Mar 29, 2013 10:15 pm
6 Pack Dart
All it does is control the spark.
Richard
PostPosted: Sat Mar 30, 2013 10:18 am
That is the MOPAR ECU, that come in various upgrades like the orange box, chrome box, and gold box for racing.
Check red link to view pictures. I am still using the orange box. Like FOPAR says, it controls spark only.
Look at DI's link for what the voltage regulator looks like and how to ground it.
 Post subject: Thanks!
PostPosted: Sat Mar 30, 2013 3:57 pm
Thanks, guys, for straightening me out. After combing through my boxes of junk, I have concluded that I threw out the old voltage regulator when I started this project over 7 years ago. Ebay to the rescue.
Dave
PostPosted: Sat Mar 30, 2013 5:59 pm
Well, discarding the VR willcause problems (unless you have an internally regulated alternator) If your wiring and alternator are basically stock, this should help.
http://i1272.photobucket.com/albums/y39 ... 5c3b49.gif
I hope so.
BC
PostPosted: Sun Mar 31, 2013 8:41 pm
Be sure and get the new style voltage regulator. Shown on the right hand view of the wiring diagram.
 Post subject: VR found
PostPosted: Mon Apr 01, 2013 7:11 am
I found the original chrome voltage regulator, but the case is badly rusted and pitted so I'm replacing it anyway. There are over 50 for sale on eBay, but only a few vendors will ship to Canada. Should be here in about 10 days. Thanks for all the help, guys.
Dave
PostPosted: Mon Apr 01, 2013 7:39 am
You might try your local auto parts store i bought my VR for about ten bucks.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Mon Apr 01, 2013 10:59 am
Whatever VR you get, be sure to check the output voltage at the battery once it's installed. I had one VR from Standard Motor (made in China)that "wanted" 14.8V at the regulator- so it was more like 15.1+V at the battery :shock: (what's that smell??).
Got another one from Napa/Echlin- it was the same unit from China with the same overcharge problem. :roll:
63 Valiant Wagon
225 - 4 bbl
PostPosted: Wed May 22, 2013 11:33 pm
Question: If you wire directly from alternator stud to starter relay stud (splicing in a fusable link of course), will that cure an overcharging issue?
PostPosted: Thu May 23, 2013 12:49 am
No, unless there is excessive resistance in the solid wire that runs from the starter relay stud to the (+) battery terminal.
PostPosted: Mon May 27, 2013 2:56 pm
While it is possible to have a faulty VR that causes an overcharge condition, it is more common to have bad electrical connections somewhere. The VR "senses" voltage at its ignition "run" wire (blue) & its case ground. So it tries to adjust alternator output to keep "run" voltage within its internal limits (something around 14.0V). For a two-wire field alt.- if voltage is low, the VR increases duty cycle to the green wire (increases ground) which increases alt output/ voltage. If voltage goes too high the VR decreases duty cycle/ ground.
If there is electrical resistance in the power or ground circuits to the VR, then the VR will read voltage level incorrectly- in order to "see" 14V the VR will increase alternator output- so you may have 16V at the battery but are "dropping" 2V through bad connections between the battery & the VR.
Possible causes are, battery ground cable at engine, engine to body ground, VR ground to body, ignition switch & connector, bulkhead connections (esp alternator /B+ batt. / ign run), battery stud at starter relay, VR connector.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Mon May 27, 2013 5:00 pm
That makes sense to me. After running directly from alternator stud to starter relay stud, overcharge disappeared. But, after switching over to Pertronix ignition, car would run for a while then die. I'm assuming that it was due to a voltage drop since I was still going through the resistance ballast. After splicing a jumper wire from one side of the ballast field wire to the ignition wire, car runs fine...so far. I did strip out all the wires associated with the ignition module as I now should have a direct 12volts to the Pertronix. I wiring diagram came in handy before making he jumper wire. I am starting to understand what goes where although there are a couple of small relay boxes that I have never seen before. One may be for the AC but the other, which comes directly off the ballast resistor, has a red plug with 3 connectors in it with a black wire to the fourth connection. Would be really nice if someone make a video of basic wiring and it's function. I still don't understand why a field wire from the alternator runs to the ballast resistor as the primary voltage source.
