It is currently Thu Jun 18, 2026 6:54 pm
PostPosted: Mon May 13, 2013 4:50 am
I have search unsuccessfully for a full engine break in. What is the correct procedure?
Service manual indicates 5 Quarters with filter change but with and completely empty engine how much oil? When in break in period is it regular oil and a break in additive or 5 quarts of break in oil? I believe I read somewhere initial startup the engine should be run at 2000 RPM for 15 or 20 minutes. I just really want to make sure I get this right. I have about 1500-1800 in this engine and blowing it just ain't cool.
I ask because I have changed just about everything.
Reground OCG Cam (791) 230 lift
New lifters
Crank ground and polished -10
New Main and Rod bearings
Silovlite Pistons +.040
Rods rebuilt
engbldr Valves and springs
New lifter rods
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Mon May 13, 2013 5:20 am
have a look here.
A good analysis of break in oils at the bottom of the page (under oil additives?) :shrug:
http://www.carcraft.com/techarticles/cc ... ewall.html
and another procedure
http://www.enginebuildermag.com/Article ... edure.aspx
Brendan.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
 Post subject: I would...
PostPosted: Mon May 13, 2013 7:53 am
With an engine not run in yet, you will need 6 quarts (5 for the standard oil capacity and oil filter...1 more for all the areas that normally have a film of oil for lubrication...if you are adding 1/2 quart of Comp Cam secret sauce, EOS, etc than only need 1/2 more quart). Put a few glugs into the oil filter before installing to help prime the engine.
Make sure everything is good (connections fuel, etc...), you can do an initial wind up with the plugs out and starter rolling the motor over until you get oil out the rocker arms...put it all back together and start the car, and set the fast idle screw on your carb to 2000 rpm, go for 10-15 minutes at 2000 rpm, for the last 5 minutes use your hand to vary the engine speed 2000-3000 every so often. Change oil check for 'bits', if good drive it for another few hundred miles and change oil again.
Good Luck,
PostPosted: Mon May 13, 2013 8:48 am
Its to bad your on the other side of the country i would not be opposed to a heads up. You have been very helpful and I think it would be a fun trip down the quarter mile.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: Lol...
PostPosted: Mon May 13, 2013 9:05 am
You can always do a road trip like Lou and Rob S had done... :wink:
:lol:
Look forward to seeing how she runs after break in and some daily driving.
PostPosted: Mon May 13, 2013 9:47 am
Me too. I am hoping for a pretty speedy little bastard. I have a bit of a heavy foot so I am sure I will drink some gas but thats ok it will be fun.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu May 16, 2013 8:02 am
So I have another question. My engine is a flat tappet and the timing is done by adjusters obviously. My question is do I need to set the adjusters before I start the engine the first time? This would be done by manually rotating the engine until the intake and exhaust are slightly open correct?
The other question is about timing. It is supposed to be set at idle but I am seeing I am supposed to run the engine at a higher RPM the idle. Do I just leave the timing as is for break in or can I set it while the engine is breaking in? If not how do I set the timing with the engine not running?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: Yep...
PostPosted: Thu May 16, 2013 8:46 am
You got it, set your valve lash a little loose from the cam spec (I bat around .002-.004 depending on the cam profile), rolling engine over and adjusting as they enter the lash range.
Unless I know what the build wants timing wise, I set it between TDC-5 BTDC for starters, then you can adjust that during break in (as long as you don't kill the engine on adjustment.
Once your 20 minutes are up, you can put it a low idle and recheck the lash and see if any improvements are made there (i.e. if too tight or just right).
:wink:
PostPosted: Thu May 16, 2013 10:06 am
Much obliged I just spent to much money to blow it and I want to make sure I understand it to prevent damage.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
