It is currently Sun Nov 29, 2026 3:49 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Wed Jun 19, 2013 8:17 pm
Red, I remember seeing you post that set up a while ago I think. It looks like it'd work pretty well.
I'm glad to have that info on the lifters as well, since ill be running those now. I haven't looked at much on post 80 engines.
 Post subject: Re: Transporting a slant
PostPosted: Thu Jun 20, 2013 8:00 am
Best case scenario; you put break-in lube on both the cam lobes and lifter bottoms, and it works, wearing in new patterns for the misplaced lifters. (I wouldn't count on this happening)
Worst case scenario; even with break-in lube and break-in oil, you destroy at least one lobe and lifter in the first 20-30 minutes of running, then get to pull the engine again, tear it down and redo everything right the second time around.
You wipe a lobe off the cam or tear up a lifter bottom, and the resulting metal particles make thier way through most of the engine, quite probably tearing up the rod, cam and main bearings in thier scenic trip. (I would count on this happening.)
Sorry to give you bad news, but those are the unfortunate realities of the automotive hobby.
Roger
Oh man, I uhh thought you guys were refering to push rods... :oops: Well at least I won't be forgetting keep the order of my lifters the if I ever pull them out...
1978 4 door Dodge Aspen, Super Six
PostPosted: Fri Jun 21, 2013 6:53 am
Got the engine and trans home safe and sound! The guy I bought it from had it strapped to a pallet so he just loaded it into the back wit the forklift and off I went.
Averaged 18 mpg on the way down, unloaded, and 19.6 on the way back, engine and trans loaded up. Guess that loose fitting tonneau cover wasn't doing me any favours!
The trans would be what...a 904? I haven't paid much attention to transmissions on our slants here. Anybody need one? I won't use it.
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
