It is currently Fri Nov 20, 2026 11:48 am
 Post subject: Housing straight-ness
PostPosted: Thu Jun 27, 2013 9:36 pm
Recently scored an original (not b/c/e housing that's been shortened) A body 8 3/4. No idea of it's past history. Should I be worried about how straight the housing is? I believe on my last one I took it to a shop to have bearings pressed on the axles and rebuilt the dropout and told them to check it for straight-ness while it was there. On this one I won't need to do shop work, but should I take it there and have it checked out? Or is it not worth it? This project will eventually turn into a daily driver.
PostPosted: Fri Jun 28, 2013 8:30 am
I would not worry. If it all turns over freely its straight enough. The only bent housing I can remember broke axles repeatedly. Thats how I figgered out it was bent.
PostPosted: Fri Jun 28, 2013 9:39 am
Gulp... I don't wanna break $300 axles!
PostPosted: Sat Jun 29, 2013 8:25 pm
If it's that bent, you can probably see it by eye. I've not seen an 8.75" housing bent.
 Post subject: Lol...
PostPosted: Sat Jun 29, 2013 8:38 pm
I took a full force hit to the 8 3/4" rear in the Fury I was running for my first demo derby...it completely wasted the trunk, rear quarter panels, and leaf springs, tore the shocks off the plates....but the rear was plenty straight and fine after getting clobbered by the welded up ford that tagged me...
It's a pretty stout rear...(much better than the 1971-1973 Ford Mustang 9" rear, for sure!)
I probably wouldn't have gotten tagged like that if I hadn't mounted a big Pacman on top of the car....
PostPosted: Sat Jun 29, 2013 10:20 pm
I watched one bend. 4 door '68 Satellite 440 4:56 gears. We thought the U joint scattered. I was filming it and told the girls next to me, "wanna see a 4 door to a wheel stand?" We noticed it was twisted the next morning. :shock:
PostPosted: Tue Jul 02, 2013 11:22 pm
Unless it came out of a heavy drag car I would not worry.
