It is currently Fri Jan 02, 2026 6:09 pm
 Post subject: new and need HELP!
PostPosted: Sat Jul 06, 2013 6:53 pm
my son was given a 74 Dart swinger 225 slant 6 that was not running...we have got the car running good at idle in park or nuetral but as soon as it goes into gear the engine rpm drops by 400 and will barely run. Timing is at tdc, valves were adjusted at .002 intake and .003 exhaust, ( my specs say .001-.003 int and .002-.004 exh) i just rebuilt the single barrel holley. Does this sound like a bad torque converter or am i missing something????? Any help would be appreciated.
PostPosted: Sat Jul 06, 2013 6:58 pm
Try loosening up the valves........ .010 and .020
Try timing at 5 btdc
PostPosted: Sat Jul 06, 2013 7:03 pm
Site Admin
Adjust valve lash at 0.010" and 0.020" Hot assuming a stock cam.
Stock base timing was set at 0° for the '74 model year. It will likely run better with 10° base. Make sure the EGR is functioning correctly, or detonation is likely when pulling a hill. The stock ignition curve probably isn't going to be ideal.
In case you missed it, the head that came on the '74 is a spark plug tube type. The washers on the threaded portion of the plug should be removed. The plugs seat on the spark plug tube at the head. The spark plugs will overheat and can cause detonation if the washers are left on.
CJ
PostPosted: Sun Jul 07, 2013 7:57 am
isnt .010 and .020 way loose?
PostPosted: Sun Jul 07, 2013 8:11 am
no.
PostPosted: Sun Jul 07, 2013 8:13 am
ok thanks then!
 Post subject: Aw jeez...
PostPosted: Sun Jul 07, 2013 9:15 am
:o
Those are the specs for the stem to guide clearances when rebuilding the head....FYI
The information in your book for the 10 and 20 will be under the heading "Clearance Between Valve Stem and Rocker Arm Pad (Engine Hot).
Bet it will work great once the lash is correct.
:wink:
x2 on setting the initial to 5 btdc...it will help.
Also, if you rebuilt the Holley 1945, next time for better performance change the main jet to a #60 and set the carb linkages to the settings shown for a 1976, the 1974 jet and settings are very lean and will lack power.
PostPosted: Sun Jul 07, 2013 4:27 pm
thanks the car definetly runs better with valve lash set right! I can only get 3degrees initial though even with both adustments?? the car still drops about 250 rpm in gear so I have the curb idle set at 900 for 650 in gear? any other thoughts?
PostPosted: Sun Jul 07, 2013 4:37 pm
Site Admin
There is another adjuster on the bottom of the distributor for the adjuster plate that allows more movement of the distributor.
CJ
PostPosted: Sun Jul 07, 2013 7:04 pm
yes even with that
PostPosted: Sun Jul 07, 2013 7:37 pm
Site Admin
Then you'll need to find TDC and move the distributor a tooth.
CJ
Users browsing this forum: Google [Bot] and 16 guests
