It is currently Fri Nov 20, 2026 2:09 am
 Post subject: Tranny fluid
PostPosted: Sun Jul 07, 2013 10:10 pm
Anyone have a recommendation for proper tranny fluid for my A-904? Any particular brand or grade better for my trans?
thanks,
BG
PostPosted: Sun Jul 07, 2013 10:12 pm
ATF+4. Pricey, but good.
PostPosted: Mon Jul 08, 2013 7:14 am
Type F............waiting for the fire storm.........
PostPosted: Mon Jul 08, 2013 8:20 am
Actually, you may want to look at Dexron 6! Sounds like a bad sci-fi movie.
PostPosted: Mon Jul 08, 2013 10:01 am
Type F here also.
Will
 Post subject: Rebuild or fluid change?
PostPosted: Mon Jul 08, 2013 10:14 am
If you're just doing a filter/fluid change, then stick to Dexron.
If this is a rebuilt tranny and it was all cleaned for a fresh start then you can put in Type F, ATF+4, etc... If you are in scenario #1 mixing Type F and the Dexron in the undrained torque convertor won't work too well (or too long).
 Post subject: ok....
PostPosted: Mon Jul 08, 2013 10:57 am
I don't mean to start a firestorm, sorry in advance if that happens.
I drained the fluid to change the filter, I didn't drain the torque converter. It was a recently rebuilt tranny. I don't know what fluid was used....hmmm. I have the engine out, so I could also drain the torque converter, should I? Any special things I should do there? I did notice some very fine shiny bits in the fluid, likely from break in wear. The tranny only has a few thousand miles on it, shifts great.
I can call the place that rebuilt the unit, but my experience was that Dexron is usually used in Mopars/GM and Type-F was for Fords. I was just asking about variations in brand...but now you've got me worried. Don't most rebuilders stick to Dexron as it is recommended for Mopars?
Why do people run Type-F in Mopars? Is it because it grabs better, more friction? My A-904 shifts awesome as it is, don't need more grab.
Thanks all,
BG
PostPosted: Mon Jul 08, 2013 11:19 am
...which said...
If you find a quality brand of ATF+4 for a reasonable price, use it.
If you find a quality brand of Dexron-VI for a a reasonable price, use it.
Sounds like sound advice...
So, I'll likely drain the torque converter and replace with one of the above fluids. I've never drained a torque converter, do I simply drain it, fill with the fluid of choice above, reinstall?
Anyone know offhand the capacity of the A-904 including torque converter?
thanks,
BG
PostPosted: Mon Jul 08, 2013 11:33 am
I'd listen to Dan's advice. I have run ATF+4 in all the Mopars I maintain for the past few years and it has worked great.
I contacted Dan via e-mail this morning and he says that Dexron-VI surpasses even ATF+4 in terms of the relevant properties for a transmission fluid.
My recommendation would be to use Dexron-VI is you want the absolute BEST fluid for your transmission. Older, inferior fluids will "work," and might even work well enough to keep you happy for decades, but the latest fluids will work better.
 Post subject: Well...
PostPosted: Mon Jul 08, 2013 12:00 pm
Yes the performance guys run Type F because it's stickier, but also more commonly available and cheaper...(litmus test here is going into the quickie mart and seeing if you can get a bottle of either off the shelf...which would be one of those, I just pulled in to the gas station and don't have a spare bottle in the trunk).
Since you are not racing and just daily driving I'd go with Dan and Reed...
But, I will give both a bad time since neither have put together
a performance slant yet (min 10:1SCR, 4 barrel, about 200hp), so they
can't say what how +4 and Dex-6 would handle repeated runs at the
track.
:wink:
PostPosted: Mon Jul 08, 2013 12:04 pm
That's true. All my wrenching has been on daily drivers and very mild performance upgrades. Still, my brother managed to burn up SEVEN transmissions in his van (including two 727s) but the 904 I built him and filled with ATF+4 has held up fine for over a year now with his crazy driving and hauling of heavy loads. Knock on wood.
What works at the track doesn't necessarily work for a daily driver.
 Post subject: Not if...
PostPosted: Mon Jul 08, 2013 12:49 pm
That is somewhat true, but I am talking apples to apples...on a "street" car at the track (which most are), everything to improve performance applies to both fields...including the drive train...it will be the trailered only cars that would not apply...
PostPosted: Mon Jul 08, 2013 1:01 pm
Less slippage with F. I have ran it in my van for 100K+ miles. Commercial use usually running 5800lbs gross or more. Pulled the Duster to Florida and back. 2200 stall no name converter and me thrashing on it. Firm shifting, no shift kit.
It's a "rug truck!"
PostPosted: Mon Jul 08, 2013 1:03 pm
OK, well, I will say run whatever you want then, so long as it is at least what is recommended by the manufacturer.
PostPosted: Mon Jul 08, 2013 3:26 pm
Type F used to be known as B&M Trickshift. Dexron is specified. ATF4 is what I run in the dually due to OD concerns and newer design. That is a must AFAIK.
