It is currently Fri Jan 02, 2026 8:02 pm
PostPosted: Thu Jul 11, 2013 7:25 pm
I am considering getting a tranaction manual valve body for my a-904. My 2 choices are #17675($294) & 17156($189). the 17156 doesn't have all the bells and whistles that the 17675 has. I have no intention for competition use, my main reason is probably avoiding the kickdown linkage when I get a super six setup, and the fun in shifting the gears. The 17156 has reverse pattern (PRND123) as the 17650 uses forward pattern. I find it more natural to using the reverse pattern, pulling the lever toward the rear. Am I correct in my reasoning for getting the 17156, beside saving $100?
Also, what happens when you put the lever in the "d" position, nothing or do you get 1st gear? thank in advance. Jerry
PostPosted: Thu Jul 11, 2013 11:28 pm
One a reverse pattern D is 1, 2 is 2, and 1 is 3rd.
One very important thing to remember is IF you do not have low band apply, you will have no engine braking in low gear. You also have to be careful not to let off and get back on the gas in low. You can roll the sprag and bad things may result.
PostPosted: Fri Jul 12, 2013 3:37 pm
thank you slantzilla
I was just on the turboaction web site, looking at the various valve bodies, looks like the 17675 has engine braking .
"You also have to be careful not to let off and get back on the gas in low. You can roll the sprag and bad things may result."
does the above applies only if you have no engine braking, or does that applies to all the manual valve bodies? thanks again
PostPosted: Fri Jul 12, 2013 7:45 pm
That is for a non low band apply. If you have LBA, you can let off and get back on, and will have engine braking.
I used a TurboAction Cheetah non LBA on the street for many years with no issues. In fact, it's still in a buddy's car and he has never had an issue either.
PostPosted: Sat Jul 13, 2013 12:09 am
ok.. thank you slantzilla
I guess LBN it will be, cost will be $100 more.
which side of the fence do you stand on the heated topic of the accumulator spring? thx
PostPosted: Sat Jul 13, 2013 1:43 am
http://www.forabodiesonly.com/mopar/arc ... p/t-6.html
PostPosted: Sat Jul 13, 2013 4:43 am
I didn't like the LBA feature, for downshifting while moving, at closed throttle. Mine would just about put you through the windshield. When I came up to a red light, I would leave it in second, untll reaching a full stop.
PostPosted: Sat Jul 13, 2013 2:57 pm
I wanna do this too, but would I really need engine braking in a drag only car?
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Mon Jul 15, 2013 5:55 pm
thanks to
emsvitil; I have a better understanding of the low band applied, to be on the safe side, I'll order a manual valve body with lba, even though I wont do any racing.
Charlie_S; I think thats how I would drive mostly, come to a stop in 2nd, then downshift to 1st for take off.
thank to everyone for tips
