It is currently Thu Jun 25, 2026 9:40 am
Post new topic  Reply to topic  [ 37 posts ]  Go to page Previous 1 2 3 Next
 Post subject: copper gaskets
PostPosted: Fri Jul 12, 2013 11:04 am
Thanks for that info, CNC Dude! I'll hold of on calling Clark 'til I hear more information from you.
Bill
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Fri Jul 12, 2013 3:17 pm
Hi, I am not an expert, but do have a ton of stories.....Started running an o'ring block about 10 years ago. No receiver groove in the head, 3.5 bore, arp studs. The o'ring was set to the outside edge of a felpro copper ring in case I had to run a felpro in an emergency. A felpro has been run on that block with about a 100hp shot of nitrous and held fine. The edge of the bore at the top corner started to degrade so the new block has the o'ring moved out further.I may have been wearing from repeated rebuilds I will try to get a picture. I have used clark and sce gaskets. I spray them with copper coat 30 min before install. Clean the block and head with lacquer thinner. With the turbo I have blown 2 head gaskets. Every thing worked fine on the chassis dyno. 15 lbs of boost. I hope to double check everything in the next couple of weeks. I have been down after foot surgery and the car has cob webs on it. .?? I will get out there and get some pictures for Random Racing soon! They have blown on different cylinders.
Will
PostPosted: Fri Jul 12, 2013 4:42 pm
old block o'ring
with felpro
new block o'ring a little further out
 Post subject: Cylinder pressure...
PostPosted: Sat Jul 13, 2013 8:50 am
Will, what gasket and O-Ring material were you using when these last two head gaskets blew, and do you know the cause? Is there a permanent fix for this?
Thanks for the pictures!!
Bill
PostPosted: Sat Jul 13, 2013 9:29 am
.050 copper gaskets, stainless o'ring. Don't know the cause yet. I have a couple of ideas, we will see.
Will
PostPosted: Sat Jul 13, 2013 9:49 pm
Thanks Will!!!
I am having nothing but major grief in trying to get O-Rings installed in this block.
It seems the Stainless .041" wire is so big (fat) it won't go down into the groove, but the new .039" is just small enough that once it's in there, it won't "stick." Comes loose at the slightest provocation.
I worked on that %#@&$*!!! all day today and the ONLY successful operation I was able to accomplish was using the .038" COPPER wire they (Isky) sent with the cutter, PUSHING it down into the groove and using some scotch tape in it to keep it positioned (!)... many pieces... like 12 pieces of tape, per-hole,
I don't WANT to use copper wire, but nothing else works for me.
I double checked the cutter's depth adjustment and after cutting all six grooves, the cutter showed no sign of dulling and, checking the depth of the cuts, resulted in my ascertaining that they were ALL.030"-deep, all the way around.... no more, no less.
I am going to buy an extra Fel Pro gasket (they only make one part number) and install it. Once it's torqued down on these copper wires, I am going to remove the head and examine the fire ring area of that head gasket CLOSELY, in the area where it contacts the O-Ring, as well as the "used" copper O-Rings to determine if they have distorted and/or flattened on top (due to the compression from the torque) so they can't form an effective high unit-loading area on that fire ring.
If it looks okay (I have my doubts) I will put it back together with the copper/Fel Pro system and try it. It seems to work for Aaron; maybe it will work for me.
If it doesn't hold at, say, 15 pounds of boost, I will have to figure something else out to use.
Wish me luck....
Bill in Conway, Arkansas
PostPosted: Sun Jul 14, 2013 2:13 am
Put some hylomar in the groove with the .039 wire
If you have problems finding it, you can get it at a Harley Davidson dealer.......
 Post subject: Hylomar
PostPosted: Sun Jul 14, 2013 9:26 am
Thanks; I will definitely try that!
Bill (pulling his hair out...)
PostPosted: Tue Jul 30, 2013 10:59 pm
Tried Hylomar BLUE and found it not QUITE sticky enough, so I did THIS:
http://www.forabodiesonly.com/mopar/sho ... p?t=173401
FINALLY an M.O. that works like charm... Just took some trial and error... LOTS of error... LOL!
Bill
 Post subject: O-Ring gaps???
PostPosted: Sun Aug 11, 2013 12:06 am
I have the head ready to go back on the motor, but have a question for anyone who has experience with O-Rings.
What is the allowable gap in the O-ring where the ends meet, or is there one? I have one O-ring installed that has about a .015"-gap between the two ends.
Is that going to give me problems with this Fel Pro gasket? Is there ANY gap allowed, or do they all have to be butted solidly together at the ends?
I need to know, so I can fix this gap problem while the head is off the block.
Thanks for any information!!!
Bill, in Conway, Arkansas
PostPosted: Sun Aug 11, 2013 12:47 am
Car Model: 64 Valiant
Try to get the gaps on the o-rings as close together as possible, but I think your bigger problem is going to be trying to run o-rings with the Fel-pro gasket, that type of gasket type is not compatible with o-ringed blocks or heads.
PostPosted: Sun Aug 11, 2013 4:46 am
I've been running A fel-pro gasket with copper wire o-ring for wire for two years on limited duty but the motor has seen up too 18psi of boost and some minor detention with absolutely no signs of head lift or water in the oil. Maybe that will change but until I see a problem ill keep running the felpro gasket.
Bill it was explained to me to cut your ends of the wire at a 45° cut on both ends and match the angles so they meet with no gap, also I tired not to have the cut ends in between the cylinder bore's.
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Sun Aug 11, 2013 4:58 am
PostPosted: Sun Aug 11, 2013 4:59 am
Here's a couple pics of mine
Aaron
PostPosted: Sun Aug 11, 2013 5:01 am
This is on a standard bore slant. There's alot of the BMW guys that do a figure 8 pattern and intersect the grooves between the bore and run only one long piece of wire that only leaves two ends to mate together ill try and find a pic on the net and ill post it
Aaron
